1934 CLUTCH HANDLE ???
OLTWOPOP
01-20-2008 20:14:01
I have a 1934 (A) that the clutch handle has a 2nd bend in it about 7" above the bottom bend. This 2nd bend makes the handle stand up vertical in place of leaning to the right. I thought that it was some modification that some farmer had made. But I was at a fellow collectors that has a 1934 (A), and it's bent just like mine. The tractors was about 2000 serial numbers apart. Does any one know more about this oddity? It's not shown in any of the books that I have.
donsdeeres
02-12-2008 21:25:35
 Re: 1934 CLUTCH HANDLE ??? in reply to OLTWOPOP, 01-20-2008 20:14:01
34 and 35 a's had a slight bend outward at the bottom only!
Duane Larson
01-21-2008 06:55:43
OLTWOPOP,
One possibility may be if a mounted No 25 two row corn picker may have been used on the tractor. Two clutch levers, J7825H and AJ5448H, were available for use on tractors with the mounted picker. In Repair Catalog 50-H only the latter is illustrated, and it appears to be straighter than the production lever.
Mounting instructions for the 25 have you reverse the clutch lever so the top points inward.
Anyway, something to consider.
OLTWOPOP
01-21-2008 16:36:50
 Re: 1934 CLUTCH HANDLE ??? in reply to Duane Larson, 01-21-2008 06:55:43
Duane I just looked at it again, there is no way you could reverse it. The steering wheel would be in the way big time. I think it is at about a 45 degree angle at both bends. I"m new to Y.T. some day I will learn how to post pictures.
Mike M
01-21-2008 06:12:58
Is it taller than normal ? May be for a corn picker ?
OLTWOPOP
01-21-2008 07:01:45
 Re: 1934 CLUTCH HANDLE ??? in reply to Mike M, 01-21-2008 06:12:58
I have an another (A) that has the corn picker handle there about 12" taller than standard handles. 1934 handles are slightly taller maybe 2" than other year models though.
