430W idle problem
Ralph D.
01-20-2008 15:18:13
Hello rusty wheel, Thanks for the reply. To tell you better on what this does. After the engine warms up the rpm's keep increasing untill it reaches full throttle. I can work the throttle with nothing happening the carb. linkage. When i shut the tractor off the linkage works fine. You mentioned something about weights, would that be on a gear inside the governor. Sorry about the hindsight, learning as i go.. thanks
430 carb
01-20-2008 18:39:06
 Re: 430W idle problem in reply to Ralph D., 01-20-2008 15:18:13
sometimes the carb to govener linkage gets against the back of the air canister and keeps it for moving freely or you mite double check you needle adjustments with the manual sometime with the load needle and the air needle out to many turns it will idle up like that ,I have had nothing but trouble with my 430 carb. good luck with yours
Rusty Wheel
01-20-2008 18:03:12
Hey Ralph. Yes, the weights are on the inside of the governor. But before you go into the governor, make sure the linkage is hooked up properly and nothing is missing. I don't have a book on the 430, but this sounds more like a linkage problem than a governor problem. The book on the MT I have shows a governor rpm limiting screw on the left side of the fan bracket. I wonder if the tractor was doing this before the carb was rebuilt. Maybe that's the reason it was worked on. Good luck..... .RW
Ralph D.
01-20-2008 18:36:01
 Re: 430W idle problem in reply to Rusty Wheel, 01-20-2008 18:03:12
Hi Rusty Wheel, Thanks i have a operators manual and a shop manual, but neither one go into the governor too much except for a complete rebuid. I will check the linkage closer.. Just had me a little stumped on this one. Appreciate the info.
