4020 Parking Pawl
TxFarmer84
01-20-2008 14:37:33
How big of a job is it to replace the parking pawl on a p/s 4020. The cover is off and I really cant tell about replacing the pawl. Does it require a major teardown of the trans. Thanks for any information. Kyle
Mike M
01-20-2008 19:52:27
 Re: 4020 Parking Pawl in reply to TxFarmer84, 01-20-2008 14:37:33
The book says to pull some or all of the tranny clutch packs out. I changed one of these once on an early 4020 and was able to cheat the book. Rockshaft housing off,tranny top cover off, I seem to remember having to remove the load and depth shaft and loosen up the load and depth arm to gain room to remove that pawl. I left the diff. and clutch packs all in there. That park on those is not a good design as one way it tightens itself up and the other it tries to force it's way out of park. Very unsafe on hilly ground. I much perfer the syncro-ranges park.
TxFarmer84
01-22-2008 09:12:14
 Re: 4020 Parking Pawl in reply to Mike M, 01-20-2008 19:52:27
So for what you remember you did not have to split the tractor or pull all the packs out? I sure hope this is the case. Thanks for all the help. Kyle
Mike M
01-22-2008 11:19:47
 Re: 4020 Parking Pawl in reply to TxFarmer84, 01-22-2008 09:12:14
I'm positive I did not have to split it and pull the packs out. This was on an early model with no diff. lock too. ( I think ? ) later models may not have the same setup. But I don't remember all the details. I am also ambidextreous (sp?) and VERY resourcefull too.
ET
01-20-2008 18:02:48
The park pawl can be replaced after pulling the rockshaft housing and transmission cover.
Texasmark
01-20-2008 15:45:43
An option would be to leave it in 1st gear and turn the engine off. 20 hrs at $100/hr would buy you a lot of something....starter brushes, batteries.
Mark
Gerald J.
01-20-2008 16:49:00
 Re: 4020 Parking Pawl in reply to Texasmark, 01-20-2008 15:45:43
That might hold it until the hydraulic pressure bleeds off. Its a power shift.
Gerald J.
Texasmark
01-21-2008 07:54:44
 Re: 4020 Parking Pawl in reply to Gerald J., 01-20-2008 16:49:00
Okaye. Grin
bob15
01-20-2008 15:11:41
It requires a double split of the tractor and removal of the rockshaft and clutch pack. I think the flat rate is around 15-20 hours.
bob
