John Deere 4430 water temperature gauge
bhelm1982
01-20-2008 08:39:48
Have John Deere 4430 tractor that will not read correct water temperature. Gauge always pegged at red line. Replaced water temperature sender in cylinder head. Does the same thing as before. Get 12 volts at wire going into temperature sender. Does this sound like a wiring problem or is there a problem with gauge or circuit board?
johns48jdb
01-20-2008 11:50:54
 Re: John Deere 4430 water temperature gauge in reply to bhelm1982, 01-20-2008 08:39:48
do you have a lot of problems with wearing out water pumps on the 4430. the guy i worked for did and when i replaced it for him i noticed that the fan belt wasn't lined up correctly. the idler wasn't slotted out far enough to let the belt line up right. i didn't have access to a mill but a little careful work with a torch and the slot was deeper. he never had any problems with water pumps after that.
Bob
01-20-2008 09:13:19
Proably a bad gauge. I have replaced a couplee. Could also be a cracked foil on the circuit board causing no ground to the gauge.
