1981 John Deere 650 2wd
Chris Witthoft
01-18-2008 14:10:18
I have a 1981 John Deere 650 2wd tractor. It has a open/close turn valve under the seat, what does it do?
Mike M
01-19-2008 05:42:52
 Re: 1981 John Deere 650 2wd in reply to Chris Witthoft, 01-18-2008 14:10:18
The rate of drop is a little lever on the LH side of the rockshaft valve should have a red cover on the handle.You have to lift up the seat to find it. That knob is just to lock the hitch up for some reasons I could never figure out ? Leave it opened all the way.
ronco
01-18-2008 16:02:53
I think it is used to lock the 3 point hitch in the raised position during transit if there is a heavy implement on the 3 point.
RobMD
01-18-2008 15:23:48
Might be the three point hitch rate of drop.
chris witthoft
01-18-2008 16:29:19
 Re: 1981 John Deere 650 2wd in reply to RobMD, 01-18-2008 15:23:48
I thought it might have something to do with the hydraulics but never thought about the 3 pt hitch having adjustments. Any other thoughts?
MSM
01-18-2008 16:42:27
 Re: 1981 John Deere 650 2wd in reply to chris witthoft, 01-18-2008 16:29:19
It is a rate of drop valve for the 3 pt hitch. The more you close it the slower a mounted inplement will lower.It is usually used on a heavier implement that wants to drop quickly. All the way closed will hold the implement in position.
