B John Deere Fan - Yellow or Green?
brians from SD
01-18-2008 11:41:38
On an early styled B (1939), what was the original color of the fan, yellow or green?
CLW
01-19-2008 14:30:11
 Re: B John Deere Fan - Yellow or Green? in reply to MB deere, 01-18-2008 11:41:38
johns48jdb said: (quoted from post at 08:33:51 01/19/08) was the whole blade yellow or just the back side?
Just the back side.
jd b puller
01-18-2008 14:20:47
 Re: B John Deere Fan - Yellow or Green? in reply to rob123, 01-18-2008 11:41:38
Brian, is this the same tractor that had the "clunking" when cranking around? What was the final resolution? Always nice to post your results when you ask for help. Might not get help next time. Some people have long memories...
brians in sd
01-18-2008 21:23:50
 Re: B John Deere Fan - Yellow or Green? in reply to jd b puller, 01-18-2008 14:20:47
My B was the one that turned over hard. Since the engine was 'new', and got flooded the cylinders got washed with gas. Several shots of oil through the plug holes did the trick, but now I am tore down again with some minor things. I haven't been running again, so I don't have much for a progress report. Thank you for checking in.
Brian
James Howell
01-18-2008 14:21:17
 Re: B John Deere Fan - Yellow or Green? in reply to brians from SD, 01-18-2008 11:41:38
Yellow on both "Uncle Earl" my 39B and "Lazarus" my 40B.
ScottOld44B
01-18-2008 13:24:51
I painted my '49 B's fan yellow, with black strips. It looks like it has four large bumble bees under the hood. The JD police don't like it but it's my tractor!!!!
raddlechain
01-18-2008 19:29:04
 Re: B John Deere Fan - Yellow or Green? in reply to ScottOld44B, 01-18-2008 13:24:51
Yeah, and I'll bet you come completely unglued if anybody says anything negative about it.
P Browning
01-18-2008 14:32:57
Would you please send me a photo of your fan blade paint scheme sometime? I rather imagine you have the black strips at an angle to give the "motion" effect. Thanks in advance. (PatB)
P Browning
01-18-2008 14:21:45
I absolutely love that idea! Your sharing made my day! Great idea -- ah but yes, you are so right that it didn't come from Waterloo that way, but that's because they had "other fish to fry"! (PatB)
Maark
01-18-2008 11:43:08
Yellow until the end of 1945
johns48jdb
01-19-2008 07:33:51
 Re: B John Deere Fan - Yellow or Green? in reply to Maark, 01-18-2008 11:43:08
JRB
01-19-2008 09:59:19
 Re: B John Deere Fan - Yellow or Green? in reply to johns48jdb, 01-19-2008 07:33:51
I'm pretty sure the entire fan was first painted green, then the backs of the blades were painted yellow with a brush.
brians from SD
01-18-2008 13:10:57
Thank you for your info.
Brian
