Heat control valve on manifold
gitrib
01-18-2008 06:21:10
We are working on our 1956 model 50. The heat valve on the manifold is froze. It cannot be moved from hot to cold or removed. We have used all kinds of penatrating oil to no avail. We have used big wrench with a cheater and tapped lightly. We ae afraid to get to rough as we might break the manifold. Any suugestions. gitrib
BushogPapa
01-18-2008 18:54:13
 Re: Heat control valve on manifold in reply to gitrib, 01-18-2008 06:21:10
Why take it out anyway...it will just freeze tight again...!!
Set it for "Cold" if you do get it loose and forget it..!!
I like to block the clutch-side heat passage with a stainless steel plate, in place of the gasket to make it really "Cold"...
gitrib
01-19-2008 06:01:32
 Re: Heat control valve on manifold in reply to BushogPapa, 01-18-2008 18:54:13
That is the problem this is set on "Hot". Thanks we will keep working to at least get it to "Cold"
F-I-T
01-19-2008 08:54:24
 Re: Heat control valve on manifold in reply to gitrib, 01-19-2008 06:01:32
If you want to go to the trouble of removing the manifold, an overnight soak under a charcoal fire will probably relieve the bind. As was said it is a tapered fit. The long heat up and long cool down in the phosphate of the ashes should help drive off the moisture and shrink the rust. Let it cool to room temp or so in the ashes, then give it wallop using a wood mallet, or a bung starter as my grandpa called them, and it sit on a block to minimize point stress.
A rosebud torch might also do the trick, but don't spare the gas if you do. Heat it all over twice as long as you figure it will take to minimize the chance of cracking. If the manifold is already cracked, you might be up against the wall.
HTH
Frank
ET
01-18-2008 06:41:33
The heat valve is cone shaped. Drive it downward to release it. It will take a good solid blow to move it.
