410 backhoe problem
Mark Steinhorst
01-17-2008 18:16:52
I have a 1973 410 backhoe that has developed a problem with the hydraulics.The loader suddenly quit working.according to my shop manual there has to be at least 1500 psi to operate the loader.if psi drops below this the priority valve cuts off flow to the loader.I removed the spring from the priority valve and now the loader works(but slowly,as does the backhoe)I put a presssure guage on the pump and it reads 900 psi (should be 2400 or so)Can anyone help or rfer me to someone who can?thanks in advance,Mark
Handyman
01-18-2008 20:02:14
 Re: 410 backhoe problem in reply to Nathan Kapp, 01-17-2008 18:16:52
Check the intake screen in the bottom of your transmission.
Roy Suomi
01-18-2008 12:17:42
 Re: 410 backhoe problem in reply to Mark Steinhorst, 01-17-2008 18:16:52
Before you go getting in a lather , check the easy stuff first..There is a destroking solenoid on the hydraulic pump front cover..This puts the pump out of stroke so the engine will start easier..Many times this solenoid and attached valve will screw up and put out partial or no hydraulic pressure..A test plug is available to put into the hole the solenoid came out of..Any Deere dealer should be able to get you one..I hope you didn't loose the shims out of the pressure regulating valve [ priority valve]..These shims adjust the pressure that it takes to unseat the poppet valve inside the spool.. The poppet inside the spool is supposed to be free to move off it's seat to allow for pressure regulation of functions..The shims and washers used to shim the poppet will after many years of use get hammered out and not allow the poppet to come off it's seat..Remove the spool and if necessary tap the poppet out with a punch and hammer and measure the shims and washers between the poppet and spring..This thickness has to go back in to keep the pressure adjustment where it's supposed to be...If these steps help , great... If not , I'm sure we can come up with other hints for you to try...Let us know..
LarrySTN
01-17-2008 19:55:29
You likely have a broken stroke control spring in the control head of the hydraulic pump.
Dave in Tx
01-17-2008 22:22:43
 Re: 410 backhoe problem in reply to LarrySTN, 01-17-2008 19:55:29
Had one do that a few yrs ago. There is a short hose in the supply line inside the right hand frame rail about where the radiator is. That hose[about 6" long] came apart on the inside and was shuting off most of the supply oil. New hose solved the problem
johns48jdb
01-19-2008 07:38:52
 Re: 410 backhoe problem in reply to Dave in Tx, 01-17-2008 22:22:43
i bet that was a fun thing to trace down.
