Can a 50 do it?
Farmer Zippe
01-16-2008 01:49:07
I have my grandpa's model 50. You know, that one that grandpa always made you drive because of the strong arm steering! I was wondering if it would have enough power to run a 400 4 row cultivator? Its always been kept in good shape and has rear wheel weights. Thanks in advance!
fixerupper
01-16-2008 18:46:15
 Re: Can a 50 do it? in reply to Farmer Zippe, 01-16-2008 01:49:07
Learned how to cultivate with an A and 400 four row. The first couple of days my shoulders ached like crazy. After that it wasn't too bad. You can use the brakes to help you turn at the end of the field. Jim
old popper
01-16-2008 14:52:10
There were a lot of 4 row front mounts on late "B" tractors. We always had plenty of hay to bale in square bales, that kept your upper body strength up for steering tractors with front mount cultivators. Aahh, those were the "good old days" The 50 should have no problem with the 4 row.
Tom43
01-16-2008 08:29:38
A four row front and rear mount cultivator would be a tremendous load for a 50 if you put it in the ground to any depth.
RobMD
01-16-2008 13:30:14
 Re: Can a 50 do it? in reply to Tom43, 01-16-2008 08:29:38
A 4 row cultivator was available for the model 420 and 430W tractors. Certainly NOT a burden for a 50.
msb
01-16-2008 06:28:29
Most of the weight is off the tractor when the culitvator is in the ground and that is when the steering is critical.It will handle it just fine.
JD 1956 60
01-16-2008 05:18:04
Cultivated a lot of corn and soybeans with a 4 row front mount cultivator on the 49 "A", 50 "A", 51 "B" and the 55 "50". All handled it just fine. Didn't really realize how hard it was to steer until we got the 56 "60" with power steering. Later put the cultivator on the 730 and that was even better.
Mike M
01-16-2008 04:18:10
If that is rear mounted I'd think no problem. But if front mounted I'd say big problem steering it ?
Ten-Twenty
01-16-2008 03:18:40
 Re: Can a 50 do it? in reply to WeirdDeere, 01-16-2008 01:49:07
Farmer Zippe,
Our 1949 "BW" spent its working life cultivating beans and beets with a four-row cultivator. Your Model 50 should have no trouble getting the job done.
