300B hydraulic sump screen--Where Is It?
Alex In Texas
01-15-2008 16:52:13
My father-in-law is wondering if his 300B backhoe has a hydraulic sump screen, and, if so, where is it located? Any help would be much appreciated.
matthies
01-15-2008 19:30:21
 Re: 300B hydraulic sump screen--Where Is It? in reply to Alex In Texas, 01-15-2008 16:52:13
As you're sitting on the tractor, find the hyd. filter under your right ankle. Now follow the rubber hose from this filter to the transmission case. Remove the fitting that is screwed in the case and the hose is clamped to. Then reach in with your finger and pull her out AFTER you drain the tranmission/rearend. chris
Alex In Texas
01-16-2008 17:29:38
 Re: 300B hydraulic sump screen--Where Is It? in reply to matthies, 01-15-2008 19:30:21
Thanks for the help Chris. Much appreciative.
