Help Requested - D running very poorly
JGC
01-15-2008 16:34:42
The engine was completely rebuilt about 4 years ago. It idled and "paraded" really smoothly until recently. Now it misses, 'hunts' badly, and appears to be running mainly on the #2 cylinder - it always favoured #1 in the past.
This is the only 2 cylinder JD I have ever worked on so my experience is limited.
What would you check in which order to find the problem!
NOTE: I plowed with it this fall and it ran great under heavy load but runs like c..p at idle and low power.
Thank you very much!
Jon
woodvue
01-15-2008 18:58:31
 Re: Help Requested - D running very poorly in reply to JGC, 01-15-2008 16:34:42
It sounds like the idle circuit on the carb could be plugged or partially blocked. Do a search on this forum for a "No wrench carb test" before removing carburator.
Steven
P Browning
01-15-2008 20:47:52
 Re: Help Requested - D running very poorly in reply to woodvue, 01-15-2008 18:58:31
"No Wrench Carb Test" is found on the JD-H site (below). Scan across to ARTICLES 1, and from the drop downs, select CARBURETORS. On the final page of that piece you wil find the test. (PatB)
Richard G.
01-15-2008 18:00:59
Pull the plugs and if they are black, get some hotter plugs.
gtx1967jewison
01-15-2008 22:39:17
 Re: Help Requested - D running very poorly in reply to Richard G., 01-15-2008 18:00:59
its not the plugs fault if its black. fix the carb. if it runs at all under load the ignition is fine.
