720 gas in oil, what do you guys think?
440 Six pack
01-15-2008 13:36:40
I have a 720 John Deere gas tractor that was overhauled last spring and used pretty regularly over the summer and fall. It was then parked and not run again until last weekend. Got it started and ran for about 15 min and then shut down in the shop and went to drain the oil. I got about 2 gals of gas with the oil. Do you guys think I could have done any engine damage in that period of time? I am doing some other work on it so I haven't put new oil in it and started it yet. What do you guys think could I have damaged anything or am I worrying about nothing.
Jon Hagen
01-15-2008 14:12:02
 Re: 720 gas in oil, what do you guys think? in reply to 440 Six pack, 01-15-2008 13:36:40
You did not put it under a heavy load, so likely no damage. Put oil in it and watch oil pressure and listen for unusual noises.
Before you put new oil in it though, I suspect you need to put new diaphrams in the oil pressure operated fuel shut off under the tank.
If a diaphram in that thing gets a pin hole, it will allow gas to backfeed through the oil line into the engine when shut down.
