B John Deere Anti-freeze drain plug
brians from SD
01-15-2008 11:06:19
I have a coolant drain plug on a 1939 B John Deere that I can not seal up, because the threads in the bottom of the head were quite corroded. I ran a 3/4 inch pipe tap through it to clean it up, and then have tried teflon tape, and Locktite separately on the plug. Neither one worked. You can turn the plug in by hand all the way without it ever tightening up. Does anybody make an 'oversize' plug or know a good way to seal it up with the plug I have, so that I don't have to tap it way out to one inch?
johns48jdb
01-16-2008 05:17:31
 Re: B John Deere Anti-freeze drain plug in reply to brians from SD, 01-15-2008 11:06:19
i had the opposite problem. i couldn't get mine out. so i drilled it and tapped it for the next size smaler plug. worked great. i have taken plugs and went to the next size bigger and used a hack saw to cut 2 slits in it all the way across and down about half way. the slits are 90 degrees to each other. i used a vise to mash the ends together and then screwed that in with a liberal amount of sealant and had it hold. i'd tape the new plug to accept a next smaller size plug so that if you try to take it out again you can hold the bigger plug with a wrench and undo the smaller one. a good coating of anti seeze between the two plugs want hurt anythig.
gtx1967jewison
01-15-2008 22:47:24
got a little carried away with the tap dont ya think? pipe thread is tapered!
P Browning
01-15-2008 12:22:04
Bryan -- How about a boat-tail plug as a temporary measure until one day you tear it down. Or fetch an expansion plug from your friends at Ace Hdwe.
Then later on, once you take the engine apart, simply have a machinist bore & tap the hole to take a 1" NPT plug. Then you will be good to go for another 60 years. (PatB)
F-I-T
01-15-2008 11:38:05
Typically, because the taper of the pipe threads is so pronounced, you can re-thread those pipe threads with no more than a 1/2 to one full turn. MAybe you went in a bit more than necessary, or you had to because of the lever of corosion.
Can you grind the hex flats off of a pipe bushing so that the threads are higher than the hex area, then turn that in using a nipple and a pipe thread lock nut such as that used on conduit, then remove the lock nut and the nipple ands use the next lower pipe plug form here on out? Or, turn a slose nipple in far enough that you can use a cap? Not pretty, but effective.
Dry fit it first, then clean it well with acetone or MEK, then use some of the better space-age locking products, or, a bead of urethane glue. Give it a day to cure. The glue should hold it tighter than the torque you'll exert in removing the new plug. Or, turn a new plug with the correct taper, run it through a pipe die of the 1" size, and there you go. You just need to snub the nose of the new plug so that it just starts to enter the new heads threads so it doesn't bottom out. I've made several over the years. It's handy when you have the tap and die in the tool box.
HTH
Frank
Greasey Hand
01-15-2008 17:45:56
 Re: B John Deere Anti-freeze drain plug in reply to F-I-T, 01-15-2008 11:38:05
Are you sure that the head in not cracked buy the drain plug? Some people tighten them to much
& the head cracks.
