730D Flywheel Endplay
Fireman Farmer
01-15-2008 09:41:02
I&T manual says .010 for endplay.I have approx. .23 endplay,original JD flywheel.It doesn't look like it has moved or is loose.Question-Could the thrust washer on the inside of the left main bearing broken and fallen off the crank thereby giving me all this endplay?Or is the flywheel loosening off and need to be tightened.Any other ideas?
Call me toll free 1-866-741-6357 so we could further discuss my problem.
Blksmok
01-15-2008 12:10:59
 Re: 730D Flywheel Endplay in reply to Fireman Farmer, 01-15-2008 09:41:02
Fireman....based on my experience, the wear point causing increased end play is the face of the flywheel spacer. It should have a spiral oil groove , but have seen many worn smooth and missing substantail amounts of material through 50 years of work.
machinery-man
01-15-2008 11:00:02
maybe the surge from the crank had worn some off the main bearing surface. I would pull the flywheel and main and see what"s going on. Per Frank you could have a better duty thrust washer manufactured to correct the clearance problem.
F-I-T
01-15-2008 10:01:57
FF:
Those phenolic thrust washers self-destruct all the time, especially when the end play gets excessive. The sideways hammering of the flywheel and crankshaft just grinds them into powder. It is not uncommon to have to replace them. At near a quarter inch of endplay, you likely need a new thrust washer (shown as .117" thick when new per JDParts.com) and you'll need to re-position the flywheel nearly an 1/8". While you are in there, examine everything else for wear. If the tin nut has not moved, and the flywheel is tight, that lateral play came from somewhere, but 1/4" sounds like more than just a thrust washer. BTW, some folks reproduce those thrust washers in brass and have good success that way. That's pretty common practice in some milling maching head thrust control set ups.
HTH
Frank
mjbrown
01-15-2008 09:58:19
Probably just 47 years of wear. I'd guess a lot of them are running around with that much or more.
mjbrown
01-15-2008 12:11:02
 Re: 730D Flywheel Endplay in reply to mjbrown, 01-15-2008 09:58:19
oops, I misread that as .023"
