Regen � Those two places you refer as �blind holes� are actually drill plugs. I believe they are Welch Type drill plugs. Those two places are where the foundry men would insert drilling equipment to create the bores for the two A134R brake adjusting pins � the two short, stubby pins that are pointed on the end, that meet with the A151R adjusting screw. See PC304 Parts Catalog, page 27 as reference. Look about 3 inches back from the bottom �blind hole� and you will find a small �� hole in the rear axle housing, immediately back from the junction between the housing and main case. Make sure this little hole is open (both sides) � it is the escape path for excess fluid trapped in the housing containing the brake assemblies. Use a quarter-inch drill bit � this is a �weep hole� and seeing that it is open is an annual event. Now � there should be no oil leaking from the �blind holes� (drill plugs), but anything is possible. Once we get past the weep hole being cleared, then lets see what results. If oil is trapped in the �bell� part of the rear axle housing, it will ruin your brake system, and yes � I suppose escape from the drill plug region is feasible. Again, checking your weep holes will probably answer some questions. And if oil is in there in abundance and your brakes aren�t holding, rear axle removal and overhaul are your only true course of action. See pages 89 � 96 of the John Deere Model �H� Restoration Guide. �Good sized job! (PatB)
