4020 LP wont start
hankntx
01-14-2008 17:08:33
my 4020 LP is turning over and trying to start and run but as soon as i let off the key switch it runs a second and dies. the solenoid will click when i turn the key on and i can hear the gas.i tried staying on the key a second after it started and it kept running but as soon as i let off it died. it started ok the day before and i disced for about an hour and half. any help will be appreciated.
thanks hank
Gerald J.
01-14-2008 19:32:31
 Re: 4020 LP wont start in reply to hankntx, 01-14-2008 17:08:33
The 4020 gas and LP use a 6 volt coil with resistance in the run circuit. An auxiliary contact on the starter solenoid applies 12 volts directly to the coil when starting. Depending on the vintage of the 4020 that resistance is a coil on the ignition switch, or resistance wire. Mine has a ceramic resistor at the coil and had some modified wiring. Something in the run circuit, can be the ignition switch, the wire, or the resistor is open. You have to trace it with a volt meter or test lamp to find where the circuit is broken.
When my gas 4020 did that, it was a Scotch tap that had been added to move the resistor from a resistance wire to the ceramic resistor at the coil. I don't like Scotch taps anymore.
I was able to hot wire the hot side of the resistor to finish raking hay that week until I dug in and fixed the open.
Gerald J.
430WLPG
01-14-2008 17:29:42
What Maark said is probably what's wrong. And that resistor maybe under the cover behind the dash if you don't see it
Maark
01-14-2008 17:14:00
Does it have a white resister in line to the coil? About 3/4"x3/4"x21/2" long.If it does replace it.
