KentWI
01-15-2008 10:28:13
Re: Value of a 1940 AR? in reply to David Siekkinen, 01-14-2008 05:30:39
David, Between 1935 and 1949 their where 17,394 unstyled AR�s built. While that doesn�t make the tractor rare it�s not an extremely common tractor either, especially in row crop country. At Waterloo expo this past year their were only two unstyled AR�s, a 1935 and my 1949 and when I attend local shows in SE Wisconsin mine is usually the only one. Now six or seven years ago you could fine a descent AR for a $1,000 but since then, unfortunately for me and others who collected the AR, the secret is out and others want to add the AR to their collections. Now in regard to value, the steel wheels by them selves are worth over $1,800, the head $400, block $250, carburetor $200, I hope you�re getting the picture. If you chose to restore the tractor yourself, total restoration in which you rebuild the tractor from the bare crankcase up with new seals, bearings, valves, rings and fenders (the ones in the picture look good) figure on approximately $2500 in parts. When finished you have an $8,000 to $10,000 tractor, this price is based on a 35 AR that I rebuilt and sold for $8,500 four years ago. Bottom line, GET THE TRACTOR it�s a good price. Good luck, Kent
