820/830 electric start flywheel/ring gear
toolz
01-13-2008 19:56:47
I finally got the proper 24 volt starter for my old 820, and bolted it to the 830 bracket that came with the tractor. I had asked here what the difference was between the pony and electric start flywheel/ring gear, but no one knew. It looks like there is a difference in diameter. I have washers under the bracket to get the right height, and will make a spacer plate the same thickness when I'm sure of the right measurement. Looks like about 3/16" will do it. That appears to be the only difference. I could have the drive gear changed from 13 tooth to 12 or 11 to possibly work with no spacer, but 13 tooth is what it is supposed to have. I measured the tooth pitch with a vernier caliper, and the starter was the same as the ring gear at 1/2". I don't know why Deere would make two different flywheels for pony and electric, but it looks like they did. This will work fine, but if anyone has an 830 electric start flywheel for sale, I would be interested. Has anyone here ran into this? Thanks.
toolz
01-14-2008 19:21:59
 Re: 820/830 electric start flywheel/ring gear in reply to toolz, 01-13-2008 19:56:47
Thanks for all the replies, and the great pictures. I looked a little closer at my flywheel, and noticed that the roots of the gear teeth were level with the flywheel in some areas, and well above in others. Not what I would call a precision casting, but it was 50 years ago. If I happen to find the right ring gear at a reasonable price, I will get it. Otherwise, it will work this way. Thanks again- Kevin
buickanddeere
01-14-2008 17:29:59
13 tooth. She needs all the rpm that electric starter can muster.
Rich Duane
01-14-2008 10:11:19
The flywheel casting numbers are the same for either electric start or cranking engine( R1304R) The ring gear for cranking engine is R342R for electric start is R20360R.
WeirdDeere
01-13-2008 20:02:54
According to the parts book, the flywheels did NOT change, just the ring gear.
Brandon
toolz
01-13-2008 21:55:59
 Re: 820/830 electric start flywheel/ring gear in reply to WeirdDeere, 01-13-2008 20:02:54
WeirdDeere- I've been told both ways, but it would make more sense that just the gear was different. So far, no one has been able to tell me what the difference is. I'm assuming the gear I have is original to the tractor, and for pony start, but the roots of the gear teeth are level with the rim of the flywheel. If the gear was smaller, the starter drive gear may hit the flywheel edge if it engages any past the ring gear. I would sure like to see a picture if anyone has one of either pony or electric start. Like I said before, what I have is going to work fine, but the right setup would be nice. Thanks for the reply- Kevin
WeirdDeere
01-14-2008 05:13:18
 Re: 820/830 electric start flywheel/ring gear in reply to toolz, 01-13-2008 21:55:59
Here are some bad photos of my 80 flywheel gear. It is pony start, of course.
From the outside:
third party image
And from the inside:
third party image
Brandon
WeirdDeere
01-13-2008 22:06:46
I'll try to get some pics of my 80 flywheel. It's off the tractor, so I can shoot both sides.
Brandon
