4240 Front Wheel Assist
Will Dobson
01-13-2008 14:22:20
The hydraulic relief valve on the front wheel releases oil when engaged. I have swapped valves so that is not the problem. Any ideas?
Roger Gutschmidt
01-15-2008 05:00:43
 Re: 4240 Front Wheel Assist in reply to Will Dobson, 01-13-2008 14:22:20
I have a 1969 JD 4020 with factory Front Wheel Assist. I had the same problem a couple of years ago with my relief valves. There is only one solution. Some machining has to be done internally on the hydraulic motors. The tolerances are real precise between the "swash plate" and housing. If this gap is excessive it will blow oil out of the relief valves. I sent my hyd. motors to: Hydro Service, 202 N Main St., Roland, IA 50236 (Ph: 515-388-4096). These guys did an awesome job and had fast service to boot. When I talked to their technician on the phone he knew those Sundstrand Hyd. motors like the back of his hand. Anyway the cost was $480 to do both motors. My FWA worked like a dream when I got them back. They had alot of power and never leaked again. For more information you can email me at: [email protected] Sincerely, Roger Gutschmidt, Gackle, ND (701-698-2310)
low budget
01-13-2008 19:04:34
Could also be restriction in the drain lines.
Will Dobson
01-14-2008 03:23:27
 Re: 4240 Front Wheel Assist in reply to low budget, 01-13-2008 19:04:34
Do you meen like a kink or hose breaking down as the oil returns to the pump?
low budget
01-14-2008 04:44:14
 Re: 4240 Front Wheel Assist in reply to Will Dobson, 01-14-2008 03:23:27
I meant a kink or hose breaking down in the small hose that returns to the transmission case. What you said would be worth checking too.
Will Dobson
01-14-2008 16:36:44
 Re: 4240 Front Wheel Assist in reply to low budget, 01-14-2008 04:44:14
Thanks, I'll check that out this week and post. I was wondering which was the return, now I know.
powertech84
01-13-2008 18:00:53
somethings's leaking more oil than the case drain can handle. could be leaking brake pistons, or leaking motor pistons.
