carb kit
430 carb
01-12-2008 19:49:59
Is it possible thet the marvel-schebler carb can only take so many overhauls before its done I have kited two differnt carbs ( 641 &688) twice and they still wont do right, is there something I am missing ? at Idol they pop and rought it seems to be air leak because the mix needle needs to be closed to do the best all gaskets are new and tight ( I can put a TSX 245 carb on the 430 Iam working on it runs smooth )getting aggrovated ,any thought out there
BUTCH GA.
01-13-2008 06:56:48
 Re: carb kit in reply to 430 carb, 01-12-2008 19:49:59
Rob.
I have a 48 "M" with a tsx245 on it having the same problem. different ones on here told me I had a plugged passage. after cleaning and working on that carb several times I had one that i had to drill out. It sure runs good now. so inspect it real close you will find it..
RobMD
01-12-2008 20:49:42
There are small passages in the carb that need cleaning out with appropriate drill bits.
430 carb
01-13-2008 09:43:24
 Re: carb kit in reply to RobMD, 01-12-2008 20:49:42
yes all passages are clean blew air through all of them and ran small wire through them also ,Iam not saying its not the passsages , I dont think it is, with motor under light load by leting clutch out a little it levels out .puzzeled
