1952 BW, Still Popping out of Third
Chris S
01-12-2008 14:50:41
Please help us John Deere Experts.
We have a 1952 John Deere BW, S/N# 306087. Previously we had trouble with the tractor popping out of third gear, we were advised that it could possibly be a bad Spring or a Bad Detent. We took everything apart and noticed that the Detents on the shaft for first, thrird, and reverse seemed quite worn, (third especially). We obtained a new shaft for first, third, and reverse as well as new springs for all of the pawls. We also put new bearings in the Left Hand Side fo the Transmission Drive Shaft. We sealed everything back up with new Gaskets and tried it. When going up a steep Hill it will hold (just as before). As soon as you start to level out and the strain is taken off of the tractor it pops out. We were told that the transmission shift lever was from a model 50 (It has threads on the end). Could this have anything to do with it? We are open to any and all suggestions. Please help us! Thanks for your time.
machinery-man
01-13-2008 06:57:20
 Re: 1952 BW, Still Popping out of Third in reply to Chris S, 01-12-2008 14:50:41
Chris, you probably didn't go deep enough, you have to check movement of the lower countershaft. This is tighened by removing shims on the outside bearing retainers. You'd have to go back and undress both sides of the case to get this accomplished. The large cone bearings get worn and drop down allowing excess clearance. The locking shifters were used on 50/60/70 tractors to stop the drift problem you're having.
Mike M
01-12-2008 16:50:38
The shift lever has nothing to do with it.
How were the bearings and end play setting on the lower shaft ?
Chris S
01-13-2008 06:30:30
 Re: 1952 BW, Still Popping out of Third in reply to Mike M, 01-12-2008 16:50:38
When you say lower shaft are you referring to the lower countershaft? We read through the service manual and it gives information on how to remove everything above it. This includes the Sliding Gear Shaft and Transmission Drive Gear Shaft, as well as the detent shaft and all of the gears. Is this necessary to get down into the countershaft? What is that tool they are using to remove and put back on the countershaft lock Nut, (figure 130-15-15). What size is it, how are they measured?
Mike M
01-13-2008 06:51:46
 Re: 1952 BW, Still Popping out of Third in reply to Chris S, 01-13-2008 06:30:30
Well from what I've seen over the years in various tractors that lower countershafts bearings are usually bad and even the darn few with good bearings are too loose flopping around in there. A simple punch and hammer will suffice on that locknut. It will burr up one of the notches some. You can make a tool or sometimes modify a 4x4 truck spindle socket to fit. I have usually bought new lock nuts as they get pretty hammered up on the back and in the threads, but I don't know if you can get them or not anymore ? The outer lip is to be staked into a spline to hold them in place so unstake this before trying to loosen one. You can drive a small modified screwdriver or punch in the spline to lift it up out.
machinery-man
01-12-2008 15:47:51
Have fixed this many times. You have a worn shaft where the 1st/3rd/gear postion is. The 50's used a locking shifter to hold this problem. Another good upper shaft, and locking shifter should solve your problem.
Chris S
01-12-2008 16:31:27
 Re: 1952 BW, Still Popping out of Third in reply to machinery-man, 01-12-2008 15:47:51
We have already replaced number ten in the part book. (Part Number B 3327R Shifter Shaft for first, third, and reverse Gears)
machinery-man
01-12-2008 17:12:13
 Re: 1952 BW, Still Popping out of Third in reply to Chris S, 01-12-2008 16:31:27
This is a locking shifter, JD came out on the 50 series to stop what is happening on your tractor...real common problem...other bearings may also be bad as Mike says on the lower countershaft...
