70 PTO Clutch Pack.
Sorno
01-12-2008 13:02:34
How is the best way to install it back into the housing. The I/T manual just says to reverse process of taking it apart. Well it pretty much fell out so I know it isn't going to fall back together. I know how it needs to go back in but how do you line up all the clutch disks to line up with the drum?
Sorno
01-14-2008 09:13:34
 Re: 70 PTO Clutch Pack. in reply to Sorno, 01-12-2008 13:02:34
Ok odd question here but how do you engaging the clutch when the PTO is out of its housing? :(
GeorgiaHayFarmer
01-13-2008 06:38:54
Take some all-thread and put into the housing bolt holes that holds your clutch plate assembly housing onto the tractor. Then assemble the clutch plate as close to lining up as possible. Slide the whole thing on the all thread. This is your third hand as the work area is really tight. Then one at a time install the plates and line them up while pushing in the whole assembly. This is a very tedious process and works well for me.
Scott
Sorno
01-13-2008 07:44:35
 Re: 70 PTO Clutch Pack. in reply to GeorgiaHayFarmer, 01-13-2008 06:38:54
This sounds like a good idea. When you get twords the last of the plates what do you use to line them up with. I was trying with a screw driver and I got about half of them but when the housing got close to where it bolts up I couldn't get the screw driver in there no more.
GeorgiaHayFarmer
01-13-2008 12:13:27
 Re: 70 PTO Clutch Pack. in reply to Sorno, 01-13-2008 07:44:35
A couple of things work when you get close to the last plates. You can rotate the assembly left and right to help try to wiggle the plates in and I usually use what ever small tools I can find. A screw driver is kinda big. I would use some wire like clothes hanger / safety wire as well as some small picks are good to. It may take a few tries and a lot of patience which is what worked for me. If you have not replaced the brake pad and do not know if it is good then I would replace it. Don't do like me and re-assemble it without putting the new pto brake pad in. It causes problems none the least of which you cannot stop the pto from turning when disengaged. The new pads with fresh gear oil don't help matters either. So if yours has the brake pad/plate in it then go ahead and replace it.
Hope This Helps,
Scott
Bob
01-12-2008 13:19:42
Having an extra drum, meshing up the splines as you install it into the spare drum, then engaging the clutch to hold the plate works for me!
Sorno
01-12-2008 13:29:53
 Re: 70 PTO Clutch Pack. in reply to Bob, 01-12-2008 13:19:42
Thanks for the quick response. I don't have an extra drum but I am sure I can line up all the splines together but how to you hold them together to slide them into the housing? How does engaging the clutch help with this?
LarrySTN
01-12-2008 13:55:06
 Re: 70 PTO Clutch Pack. in reply to Sorno, 01-12-2008 13:29:53
It is nearly impossible to properly align the disks without the drum. Engaging the clutch holds the disks together while you install the clutch in the housing. If you don't engage the clutch, you don't need to bother with disk alignment as to gravity undoing the alignment when you try to install the clutch unit.
