530 steering
jp88
01-12-2008 09:38:04
The steering locks up occasionally,sometimes it lets loose easily and sometimes it is hard to get freed up.Could this be a pressure problem rather than a gear problem?The gear looks fine up top and I am going to remove the worm gear and get a close look at it.If it is a pressure problem could one tell me what to adjust to make it better.
Mike M
01-12-2008 11:45:28
 Re: 530 steering in reply to jp88, 01-12-2008 09:38:04
Look at that worm gear for chipped end where the pins ride in and also the cam surfaces. Do not attempt repair of this system without
SM2050 proper function of this steering CAN BE a matter of life and death.
F-I-T
01-12-2008 10:22:35
Locking up can occur when the actuator poppet sticks and the pressure continues to flow to the pedestal rotary cylinder. It can also occur if a piece of broken spring or a fragment of a pin causes the valve to stick. You can try increasing the flow rate (it's not a pressure thing, as the pressure is regulated, but the flow is adjustable). That might get you over the hump, but I think you will most likely have to open up the actuator valve and examine it for needed repair.
Frank
