JD 400 tlb
Stan S
01-12-2008 08:37:55
Hydraulics were getting slow on my old 400 so I changed both filters cleaned the screen and replaced the fluid. Now I have no hydraulics, no power steering, no forward motion. Reverse works just like it should. Anybody have any ideas?
scooter01922
01-13-2008 17:29:46
 Re: JD 400 tlb in reply to Stan S, 01-12-2008 08:37:55
No hydraulics at all ??? My 400 wouldn't move due to a poor fitting pin in the reverser linkage but everything else worked. Do you have a destroker installed??? If its the electric version and it's not working correctly that certainly would cause a lack of hydraulic function. Sorry i can't be of more help....bit of a newbie
Scott
Roy Suomi
01-12-2008 19:38:03
I would start with the clutch pedal linkages..Especially the cross shaft that goes across the front of the reverser..Loose or missing , broken pins can cause a ton of problems..Go to archives and look up 300, 400, 310. 410, reverser problems..We've covered them all there...
Stan S
01-13-2008 09:14:35
 Re: JD 400 tlb in reply to Roy Suomi, 01-12-2008 19:38:03
Thanks for the info Roy, I'll look at that.
