JD 50 CLUTCH ADJUSTMENT
Alan Williamson
01-12-2008 05:51:54
A year ago I purchased a jd 50. The clutch lever tension appeared to be the proper adjustment. A year later the lever takes very little effort to engage. Is it normal to have to keep adjusting the tension every so often to keep within the factory tension spec's of 40 to 80 ft lbs of pressure? I know how to adjust the clutch, but I wasn't aware that you had to periodically readjust. Please advise.
Thanks
John Van Valkenburgh
01-14-2008 18:59:52
 Re: JD 50 CLUTCH ADJUSTMENT in reply to Alan Williamson, 01-12-2008 05:51:54
Alan,
Perfectly normal to have to adjust the clutch once a year or even more frequently depending on how much the tractor is used.
I found that there was not much adjustment I could do before the castle-nuts would get too far back from the cotter pins. I seem to recall that there are two cotter pin holes in each of the three adjusting bolts. I used a thin washer under each nut to back within range.
When you do adjust the clutch remember that a little movement on each nut goes a long way. Just turn them one or two flats at a time and of course adjust tension on all three nuts equally. This should help to reduce any jerkiness when engaging the clutch.
Now is a good time to check the adjustment of the pulley brake. The brake pad should contact the belt pulley immediately after pulling the clutch "out". If the pulley brake is too loose you may actually be able to pull the clutch handle back far enough that it causes the clutch to being to engage again.
Best of luck,
John
1953 Model 50.
55 50
01-12-2008 10:13:00
As the others said, it's normal to have to re-adjust. One thing to help minimize the frequency of adjustment is that every time you have the clutch dis-engaged and the engine is not shut off, to just shift the transmission to neutral and re-engage the clutch. Takes a bit more time, but I am in the habit of doing that and it's just a no-brainer for me now. On tractors and other vehicles with foot clutches, we do that all the time and never think about it.
Tom43
01-12-2008 08:52:38
Yes. If you use the tractor, you will be adjusting the clutch until either you or the tractor die.
Randy G.
01-12-2008 08:50:57
I just re-adjusted the clutch on my 50 2 days ago. To me, its just routine maintenance and frequency depends on a tractors usage. RG
