1936 A oil presure
Ed K
01-12-2008 03:03:31
I am setting up a auction that has a 1936 "A" or a general purpose tractor. It has an older restoration done but when I started it it blew oil out around the oil filter cap. I replaced the filter and gasket and it did it again so I put 2 gaskets on thinking it was bottoming out on the bolt. It still does it what is causing this. Thanks Ed
Maark
01-12-2008 09:55:56
 Re: 1936 A oil presure in reply to Ed K, 01-12-2008 03:03:31
The casting that bolts to the top of the oil filter canister is probably broken. The oil filter cap will not tighten because of that. The only solution is to replace that casting part# AA861R You can remove the crankcase cover and look inside with a flashlite, you will see that casting where the oil lines fasten to it.To replace it you will need to remove the filter, then the oil filter outlet. It looks like a tin pipe with a tin washer mounted to it. There is a hole in the side of that pipe to hook a rod into to pull it down and out. There wil be 3 bolts under that, they hold that casting in place. Check and see if the top of the canister is bent down from over tightening also.
