The two fuses that I have are: 1 in the actual switch and 1 in line. Looking at the manual (link below) part 12 is an inline fuse holder. I did rewire it since there was no wires when I got it and used the same size wires Pat recommended in a previous post. Posted here for reference: ----- ----- ----- ----- ----- ----- ----- P Browning 10-09-2007 00:48:22 Re: Electrical on a 46 B in reply to patsdeere, 10-09-2007 00:10:15 I think you are confused as to what all the light switch controls on your tractor. You should go with the size and configuration switch as called out in your parts catalog. As for fuse and wire sizes, see below an excerpt from the JD-H Restoration Guide. I rather imagine your tractor's wiring system will be similar. (PatB) ----- ----- ----- WIRE RUN LIST FOR MODEL "H" TRACTOR Wires to individual lamps are 14 AWG; when two or three are combined, wire size is 12 AWG, black. Wire from Gen (F) to Light Switch Resistor terminal, 14 AWG, yellow w/green tracers. Wire from Cutout Relay (BAT) to Ammeter, 10 AWG, yellow w/black tracers. Wire from Ammeter to light switch (B) is 12 AWG with in-line fuse holder, yellow w/black tracers. Wire from Ammeter to Starting Motor is 10 AWG, yellow with black tracers. Battery Cable from Battery (-) to Starting Motor is 1 AWG. Battery Cable Battery (+) to Tractor is a Ground Strap sized at 1 AWG. Wire from Cutout Relay (GEN) to Generator "A" is 10 AWG, black. All conductors are stranded and cloth-covered, and all terminals are closed loop type, no spades. Light fuse size is 20 amp -- smaller or larger will not do! Restoration Site, JD H ----- ----- ----- ----- ----- ----- ----- -----
