sawyer
01-11-2008 10:33:25
hello im woundering what the easiest way to get a tractor engien unstuck my friend told my to poor karosine in it and it will loosen ii up.
P.S. it is a 1949 John Deere "B" if it matters
P Browning
01-11-2008 17:00:38
 Re: ??????? in reply to sawyer, 01-11-2008 10:33:25
Check out a new product I found this week called SP3. See the website below for more data to include a contact telephone number where can order. (PatB)
almrm
01-11-2008 12:56:29
On the late styled A and B the counter weight on the flywheel is on the outside. A standard pry bar will fit very well with the tip on the counterweight and one of the bolt heads for a fulcrum. This allows good leverage to pull it loose and in my case it was quite secure. The bar would stay in place after I let go of it. As stated with other solutions, take off the tappit rack as a minimum, and I took off the head. I just used penetrating oil and other oil and pulled it some whenever I went near it and it was loose in about a week. I cannot see the rings but it has compression and no damage to the rods. This method could apply tremendous rotational torque on the crank. Be reasonable with force and patient and I believe it will come loose with no damage.
Good Luck,
Mark
Kris A NC
01-11-2008 12:53:05
I just freed up my '36 B. I had Diesel in the cylinders for the longest time with no luck. I finally decided to pull the head. I got the head off and applied a MAP gas torch to the bottom of the piston and cylinder...after a few minutes I grabbed the flywheel...she inched a long...did the same thing to #2 cylinder and she was rotating 360* in a matter of 30 minutes after initial heat and head removal. Now I am not sure if that was proper to put heat to the block and pistons, but it worked for me. My .02
Kris A NC
James Howell
01-11-2008 12:37:25
What's the easiest way to free it? This may not be the easiest or quickest way to free a stuck motor, but it worked for me.
Lazarus, my 40B, had a stuck motor.
third party image
I removed both spark plugs and petcocks and used an air hose to �blow out� a mixture of diesel, water, and other unidentified materials.
I then added PB Blaster up to the spark plug threads on both cylinders.
I agree with machinery-man�s advice: Take off the valve cover and make sure the valves are free or you may break a rocker arm.
After 6 months of other projects and �honey do�s�, I removed the head.
There was one broken valve and three stuck valves.
I used a 3� wrench that was left over from my early years at the steel mill.
The wrench is made of 1� hex steel and shaped like an �F�.
Put the wrench on the flywheel and added another 2� cheater pipe about 4� long.
After applying my full weight, 160lbs of pure muscle, the flywheel moved about an inch.
Turned the wrench over, put the cheater pipe back on, and worked in the opposite direction.
After about 5 or 6 more tries, the flywheel made a 360 complete turn.
I will take the pistons out, put in new rings, and hone the cylinder walls while it is apart.
Hope this helps. Good luck with your project.
machinery-man
01-11-2008 11:18:47
depending on how hard it is stuck you might be able to free up at flywheel....take a come along and rotate a chain around the flywheel with a pull....keep some tension on the wheel, soak your cylinders then ever do often strike a pounding blow to the outside of the wheel to make a jar(not trying to beat on wheel) then tighten come along. Do over tighten as this might put too much strain on rods...then if you can get some movement going you can rock the wheel back and forth while lubricating and you might be lucky....if you can get on good revolution you're home free...I'd be sure to pull rocker arm just in case a valve is stuck as not to break the rocker arm or bend a push rod...
BUTCH GA.
01-11-2008 10:59:45
I just freed up a farmall super "A" that was stuck for 2 years using P B BLASTER AND MARVEL MYSTERY OIL. took several days but it finally broke loose.
patsdeere
01-11-2008 10:59:17
Figure it took a while to get stuck, so expect it to take time to get it unstuck.
You can try putting all types of goop (diesel, magic mystery oil, wd 40, any type of penetrating oil, etc) in the cylinders, but you won't be able to get all the way around since they are horizontal. If you aren't planning on tearing it apart that is about the best you can do. Try turning it over on a regular basis. You might see if you can raise the front end up so the destickum juice can get to more parts of the piston.
I found taking the block out and supporting it on some lumber I could then dump all kinds of stuff into the cylinders to try and get them to come loose. I had 1 that just fell out the back of the block after about 20 minutes of soaking. The other one soaked for a week and then I drove it out with a 4x4 and a sledge.
Enjoy breaking it loose. Just becareful you don't break/bend anything because then you will be teed off that you screwed something else up (I know from experience).
