720 Engine rebuild
woodvue
01-11-2008 09:33:17
third party image
third party image
#1: Have the engine tore down on a 720D and found one broken ring and a piston with a crack in it.(Still ran decent) I sent the block out to the machine shop and they said the bores are wore about 0.013, and wondered what I want to do with it. Knowing that I have to put new pistons in anyway, should I have it bored to 0.045 or leave it as is and put in standards? Block has no cracks and deck is flat. With the amount I will be investing, I want it to be right.
#2 How do I know what size rod bearing inserts are in the tractor. The ones that are in it say FM 11 64 on them.
Thanks
Steven
Earl - IL
01-12-2008 13:29:09
 Re: 720 Engine rebuild in reply to woodvue, 01-11-2008 09:33:17
Take your rod brgs to a machine shop & measure with a Ball micrometer. Measure the brg in the middle of the brg,the parting line of the brg. (where the two halves meet is thinner by .001-.0015 ) The middle of a std brg should measure .1255 A .010 brg would measure .1305 each half .005 thicker. I would mike (measure) the crankshaft if I was doing it. Std is 3.748-3.749 by my Federal Mogul manual.Ideal rod brg to crank oil clearance should be .003-.004. Earl
Mike M
01-11-2008 09:42:50
Well for sure bore it and install oversized pistons. And as for rod bearings don't even go by what was in there as who knows if they were even right ? go by what the crank measures. You may end up needing to grind it ?
Blksmok
01-11-2008 09:54:42
 Re: 720 Engine rebuild in reply to Mike M, 01-11-2008 09:42:50
The 11 64 on the rod bearings means they were made in November of 1964 and are probably std. bearings.
