36B compression relief petcocks
J Boshears
01-11-2008 06:06:10
I am restoring my 36 B which was disassembled when I got it. The cylinders on my tractor don't have the comression relief petcocks. Should I put a set on mine? The tractor has a set of hollingsworth compression inserts that were in it when the tractor was taken apart. I had the cylinders honed and have a new set of rings. How hard will it be to start without the compression relief petcocks?
jd b puller
01-11-2008 17:14:24
 Re: 36B compression relief petcocks in reply to bbaro, 01-11-2008 06:06:10
You shouldn't need them. My last B was 320 cubes and 11:1 compression and hand start. Make sure it's tuned. Remember, you don't have to spin it over fast, it just has to go over center. The Mag will take care of the rest. If you try to jerk it over, it just isn't going to be fun.
Big Country - IL
01-11-2008 14:26:42
 Re: 36B compression relief petcocks in reply to J Boshears, 01-11-2008 06:06:10
My '36 B does not have them...it is easy to start, you won't need them (they didn't originally have them then)...
440 sixpack
01-11-2008 13:55:51
I have a 38 B that does not have petcocks. I don't think they had them until the styled B's came out.
Mike M
01-11-2008 08:05:20
I have had a few short frame B's and they didn't have any. I would be afraid of drilling it for them for fear of hitting water.
Kris A NC
01-11-2008 07:08:18
If memory serves me correctly they came out in late "37 with the long frame B or in "38...not quite sure.
Kris A NC
L. A. Lamb
01-11-2008 07:06:44
Get a M M and you won't have to worry about it L A
Kendog
01-11-2008 06:17:48
My 36BO doesn't have RPs' either. You'll learn the sweet-spot on the flywheel when starting yours and will have it started in 1 or 2 rotations. I would not put them in.
