3020 three point lift capacity
SRW
01-11-2008 04:57:15
Does any one know the lift capacity of the 3020 three point.
sodly
01-16-2008 08:51:52
 Re: 3020 three point lift capacity in reply to SRW, 01-11-2008 04:57:15
If I'm not mistaken it's between 3000 and 3500 lbs. I was thinking 3500 was the number, but I'm not positive.
srw
01-16-2008 09:11:44
 Re: 3020 three point lift capacity in reply to sodly, 01-16-2008 08:51:52
Thanks,
I thought it should be in that area but being a 65 model and well used I don't know if its up to snuff or not. I have a service manual ordered that may tell me how to check it and about adjustments if any.
Texasmark
01-12-2008 06:35:33
What do you want to lift? Shouldn't have a problem with a wet 5x6 roll of hay which will come in around 2000#. You'd have more of a problem keeping the front end on the ground I'd think before you'd exceed the lift capacity. Besides, there is a hydraulic pressure relief valve that will keep you from breaking anything.
Mark
srw
01-15-2008 17:50:42
 Re: 3020 three point lift capacity in reply to Texasmark, 01-12-2008 06:35:33
Thanks,
I've got a hi lift bale spike that lifts like a post hole digger. So an 800 pound bale takes alot more force to lift. It works but it at its limit.
