Front loader -Model 260 - dismount
Estaben
01-11-2008 04:28:38
Recently aquired a model 260 quick dismount front end loader. Would like to hear the preferred procedure to dismount and mount this loader. Never have done this.
mjbrown
01-11-2008 10:27:15
 Re: Front loader -Model 260 - dismount in reply to Estaben, 01-11-2008 04:28:38
The manual is a good investment on this loader. Lots of usefull and safety related information especially about dismounting. Be careful it can bite you.
jamie smith
01-11-2008 06:19:20
Have bucket or similar on . Find firm level site raise loader , tilt forwards 45 degrees and power loader down until front wheels are 6 inches off ground . Dismount and pull the square pins located at top of tractor brackets , the disconnect parking legs from underside of loader beams by removing pins , let leg slide down beam a few inches then turn leg to face backwards and reinstall pin in top of leg . Repeat on other side . Back onto tractor , release handbrake and raise loader control until wheels touch ground . Then operate control to crowd (tilt back) bucket until bucket is level , this will lift loder masts from tractor.
Stop tractor and operate control lever(s) to relieve pressure and disconnect hoses ( a good tip is to get some coloured cable ties to mark hoses and couplers). Store hoses on loader frame to clear tractor and reverse out . To remount just reverse the above, just make sure that the bottom of mast locates on round bar at bottom of tractor bracket.
