#5 Mower Seal Replacement
Nathan Kapp
01-10-2008 13:56:21
Howdy all, I have a restored number 5 mower and it is leaking fluid out the lower shaft by the flywheel. I have a new seal for it and would like to know how difficult they are to replace. Thanks for your time.
Nate
Nathan Kapp
01-11-2008 16:40:50
 Re: #5 Mower Seal Replacement in reply to Nathan Kapp, 01-10-2008 13:56:21
Thanks so much for the advice. I need to get it ready for spring and will be spending my spring break doing so. Thanks again.
nate
Larry i n WNY
01-11-2008 09:09:24
I changed my seal by removing the rear cover, unhook the chain, use a brass punch to loosen the sprocket (it has left hand threads), then pulled the shaft & flywheel off as a unit. Then I used a shop press to get the flywheel off the shaft. If the shaft has a groove worn in it the new seal may not help much. Some older seals were double lipped, but now are single. If you can get 2 seals in there it will work, but I haven't tried it. You may need a machine shop to cleanup the shaft with a grinder and find an undersized seal.
Larry
Rich Va
01-11-2008 05:41:03
Condensed version of how I replaced mine. 1.Started soaking flywheel, shaft and key with PB blaster a week before. 2. Remove the brace that goes from gearbox to hitch area. 3. Drilled a small hole in the key and tapped it out so I could attach a piece of flat bar with screw. 4. Pulled out key,then flywheel will come off with no problem with slight tapping from hammer. After flywheel is off unbolt the flange that has the seal in it. Much information in the archives.
Bob
01-10-2008 22:56:34
Here's a couple of photos of pages from the owner's manual, showing what's in there. Key #22 is SHIMS, used as needed to set endplay. They were originally available in 4 thicknesses.
Third Party Image
Third Party Image
James Howell
01-10-2008 20:06:20
I also have the same "leak" on one of my #5 mowers and may end up changing the oil ring.
First I am going to spend some extra money to buy 140W gear oil as the operator's manual suggests.
Bob has made a good suggestion about checking the archives.
I found these two posts that might help us:
On the flywheel, yes they pull off the shaft, but I've removed some that were really difficult. It is possible to remove the flywheel and shaft as a unit from the front, if you remove the rear cover, chain, and chain sprocket, and then you have to remove the brace that connects to the bottom of the case to allow clearance for the flywheel/shaft to come out forward.
If you decide to remove the whole unit from the front be aware the chain sprocket threads onto the shaft. Easiest time to remove it is before you remove chain so you can block the pto shaft and turn the flywheel.
Hope this helps both of us. Good luck with your mower.
Bob
01-10-2008 14:17:03
It can be a bit of a nasty job to get the key out and the flywheel removed.
Try looking in the archives... I recall there being several posts in the last year, alone, from guys who have done this.
