SEDIMENT BOWL, JOHN DEERE 520
ALCHECK
01-09-2008 14:05:15
HI,CHANGED OIL FROM 10W30 TO STRAIGHT 10W, STARTED TRACTOR AND OIL LEAKING FROM SEDIMENT BOWL. TOOK IT OFF AND CLENED IT UP, PUT NEW GASKETS IN, STARTED IT UP AND STILL LEAKING OIL.THE TWO LINES ARE ONE TO THE TOP OF CASE FOR OIL PRESSURE, OND THE OTHER ONE RUNS TO THE OIL PRESSURE GAUGE CORRECT? COULD IT BE PUMPING TOO MUCH OIL PRESSURE. IS THERE AN IOL PRESSURE SWITCH SOMEWHERE THAT COULD BE BAD? IT NEVER LEAKED ANY OIL BEFORE I CHANGED OIL IN IT. IF SOMEWHONE KNOWS HOW TO FIX THIS PROBLEM, PLEASE LET ME KNOW, THANKS ALCHECK.
Kemper
01-09-2008 17:30:58
 Re: SEDIMENT BOWL, JOHN DEERE 520 in reply to ALCHECK, 01-09-2008 14:05:15
Rob
Why are you worried about the 10wt oil?
my operators manual says use sae 10wt below 32 and if temps are below -10 use sae 5wt.
Not that i would ever use 5 wt but the engine is designed for it. i know around here sometimes 10 wt would be nice on a cold morning.
ALCHECK
01-10-2008 14:44:34
 Re: SEDIMENT BOWL, JOHN DEERE 520 in reply to Kemper, 01-09-2008 17:30:58
hi, the main problem is the oil leaking from the diaphrams in the sediment bowl. do you a guy should try some indian head schlak oround the endes to try to get a better seal? thanks alcheck.
RobMD
01-10-2008 15:34:52
 Re: SEDIMENT BOWL, JOHN DEERE 520 in reply to ALCHECK, 01-10-2008 14:44:34
Shouldn't ever have to! You sure all the surfaces were clean and burr free? Sometimes, if you have that little flat piece of aluminum UPSIDE down in the assembly, you can get confused, and it will leak.
RobMD
01-09-2008 22:01:27
Is that what it's for? Just below 32... hmm, better get my facts straight.
I dismiss my comment on the type of oil as irrevelant. Thanks for the pointer :)
RobMD
01-09-2008 14:45:22
~First you need to know how the shut-off works. When the tractor is shut off, the oil pressure relieves, and the diaphragms in the assembly are free to return to their deflated state. This in turn allows the little plunger with rubber washer visible inside the glass to fully shut off, eliminating any possibility that the carb will overflow due to a leaky needle valve and seat.
~Oppositely, if the tractor loses oil pressure while running, the diaphragms inside will shut off the flow of fuel, thus "automatically" (however somewhat slowly it may be) shutting the engine down.
~In your case, there is NO oil pressure switch of any kind. In fact, the fuel shut-off itself is a kind of "oil pressure switch" as indicated above.
~Additionally, I have NO IDEA why you are running straight 10 weight in the engine, as this viscosity will thin out as the engine gets warm. If you live in Canada where it is like 0 degrees, then maybe 10wt. is sufficient. Generally, in any of the mid to southern states, you're supposed to run 10w-30 or similar.
~When you say "gaskets", do you mean the diaphragms? replacing these usually stops leakage of oil. If you have already done so, then I suspect an oil line fitting problem. Either the ferrules are bad, or you just have crappy lines. Yes, the oil line comes from the crankcase to the diaphragm and also to the gauge.
~put 10-30 back in it!
