1020 questions
wikevin
01-09-2008 09:16:29
Hello I had some 1020 gas questions, Would one of these be able to pull everything I currently pull with my 50? ( 8ft kba disc,2 - 16 plow, 1 row new idea picker, 15a flail chopper, and hopefully soon a small baler.) Are they live pto,powersteering, do they have differential locks, what loaders would fit them and what should I expect to pay for a loader? Thanks in advance for any and all answers. Kevin
Acadianbob
01-14-2008 18:09:18
 Re: 1020 questions in reply to wikevin, 01-09-2008 09:16:29
I have a model 47 loader on my 1020 with some rear wheel weights. Awesome little tractor. Mine has live PTO, 2-stage clutch, locking differential, power steering. But I don't believe they were all equipped that way. I highly recommend this tractor for hobby farm work. I believe that there is a bracket/brace that parallels the engine that is recommended with a loader to reduce stress on the engine casing.
machinery-man
01-09-2008 12:59:40
In reference to failed, I meant that standards on the 10 series were noted by many John Deere customers to be below their expectations, however they were coming out of the tourqy 2 cylinder engines. Also on the hydraulic pump am quoting my friend it may have been JD but he said it was an aircraft or aircraft designed pump and they wanted to remedy their hydraulic pump. I had a later series 1010 and it was designed away from the 430 rear end. No offense meat to 10 series owners.
machinery-man
01-09-2008 12:07:34
I have a 1020 and it most certainly would pull all of the equipment 40 H.P. I'm not sure the # of loader used maybe 45? Personally I think front axle somewhat light for loader as they really beefed these up in later models but for light use probably okay. The 1020 has live power, and most have power steering but believe some were sold without. These are one of the best smaller tractors John Deere ever built and saved John Deere reputation after the failed 10 series. The tractor uses a front engine mounted hydraulic pump(an older friend of mine, x JD mechanic said they used an aircraft landing gear pump)as they had had some many hydraulic problems with the 10 series.
Handsome Jim
01-09-2008 13:19:40
 Re: 1020 questions in reply to machinery-man, 01-09-2008 12:07:34
We have a #37 loader on one of our 1020s. It does OK so long as you remember what size tractor you're working with and keeping in mind how light the loader is built. It's possible you could tear up that loader with that small of a tractor.
jdemaris
01-09-2008 12:39:14
I agree that the 820-830-1020 and 300 series tracors are about the best small utility tractor Deere ever built. All of the above are pretty much the same tractors with some variations in options and hydraulics.
That being said, the 1010s were not THAT bad. Some models were pretty good, and some were awful.
The 1010 although often badmouthed - offered several Deere "firsts" or innovations. Because of that, I suspect their value will keep going up. 1010s and 2010s are the first Deere tractors to have Stanadyne diesel injection systems with rotary pumps. Also the first full-size Deere engines to have wet-sleeves. Also - the 1010 crawlers were the first to have the hydraulic reversers that went on to get used for many years in newer crawlers.
The 1010 crawlers were very good machines. The 1010 series lived for five years - so I wouldn't call it a complete failure.
In regard to the hydraulic pumps, the early 1010 crawlers had Webster-Electric gear pumps, and later used Cessna gear pumps - just as many later Deere crawlers and some 1010 wheel tractors do. There was nothing wrong with the Webster pumps and Deere kept using them in other things, e.g. their winches. If anything, the Websters are built better than the Cessnas,not worse - but I suppose they were also more expensive.
As far as the 1020 having an aircraft type pump??
I'd like to hear more about that - you've got me stumped. Cessna is an aircraft company - and they made the crawler and 1010 wheel-tractor gear pumps. The 1020s used a German-Deere-built four or eight piston pump as standard equipment - and some 1020s and 300s also have the bigger U.S. built 2.4 cubic inch piston-pump. As far as I know, all those piston pumps are Deere designed and built.
About options - Deere offered the 1020s and 300s with ground-driven PTO, independent clutch-driven PTO, or hydraulic live PTO. Also offered a hydraulic hi-low or a hydraulic reverser as options.
In regard to loaders - some were sold with heavy-duty loaders - e.g. the industrial 1020 sold as the 300. Many came with front loader and rear backhoe.
