Decal placement
patsdeere
01-08-2008 22:48:34
I was just looking through my decals and had a couple that I wasn't sure where they went.
The first is the PTO one. Does it go on top of the shield, the sides or ?
Second I have one that says "Model BN". It isn't one of the round type like are on normal Bs, but since I only got 1 I was wondering where it would go.
Third the one with a deere jumping that is supposed to go on the differential (according to the instructions included with the decals), but since I have a hydraulic unit on there, I guess I just don't use it?
As always, thanks in advance.
CLW
01-10-2008 20:49:16
 Re: Decal placement in reply to 630man, 01-08-2008 22:48:34
patsdeere said: (quoted from post at 17:21:53 01/10/08) I got all the easy ones on.
The big john deere words that go on the side of the hood are centered (from what I have read). Is this center point based on the length of the main hood only? Or do you include the battery cover and/or the grill?
Thanks.
You would center it between the front seam of the battery cover and the seam between the hood and grill.
patsdeere
01-10-2008 16:21:53
 Re: Decal placement in reply to patsdeere, 01-08-2008 22:48:34
Thanks.
Tom N OK
01-09-2008 10:56:47
I found this quite interesting even though it may not help much on the pan set tractors but if it has the battery box under the seat.
http://www.antiquefarming.com/PDF/JD_GP.pdf
4020LP
01-08-2008 23:09:07
What year Model "BN" do you have? If it's prior to serial number 201000, the model decals didn't go on the grille sides, it went on the seat channel, readable downhill on the clutch pulley side.
patsdeere
01-09-2008 08:28:47
 Re: Decal placement in reply to 4020LP, 01-08-2008 23:09:07
It is a 46 which does make it below the 201 cutoff. Thanks for the info on the "model BN" placement.
patsdeere
01-08-2008 22:56:00
One other question. Don't all the Bs have the letter B in yellow on a black circle that goes on both sides of the front grills?
Thanks.
P Browning
01-08-2008 23:52:42
 Re: Decal placement in reply to patsdeere, 01-08-2008 22:56:00
MODEL DESGINATOR DECALS -- To repeat an earlier comment, I put it another way. If your tractor has a pan seat, the "B" in a circle IS NOT TO BE USED! For Pan Seat tractors AFTER 1935, the model designator goes on the seat channel, roughly centered up and down, and reads from top to bottom, best viewed from the pulley side -- much like the "H" tractors, and you can see pictures by going to the JD-H Site (below), scan across to ARTICLES 1, and from the drop-downs, select DECALS.
Model designator decals are by far the largest item of decal abuse -- of decals being plastered onto tractors that do not belong there. This is why I stress buying your decals from a reliable source wherein you are less likely to receive decals you do not need, and your decal source can be contacted for added instructions if needed. I rather imagine there are a number of people out there who buy decals off eBay for example -- and I see absolute abominations being offered there every day -- makes me ill. You can always call Travis Jorde (Jorde Decals) or Kent Kaster (K&K Antique Tractor) and they will most likely tell you what else you need to know. These are to two longest-standing vendors of decals that I know of, and staying power stands for goodness. (PatB)
patsdeere
01-09-2008 08:27:45
 Re: Decal placement in reply to P Browning, 01-08-2008 23:52:42
Thanks for the info.
I did take everybody's advice and got mine from Jorde.
