How much to mill off of A2325R head?
CenTexFarmall
01-08-2008 21:22:09
Has anyone had long term problems with milling significant amounts off of the "AllFuel" (A2325R) head? By significant I mean .125 or so.
I'm working up a gas conversion and am looking at ways of boosting compression. There appears to be a lot of meat but the area I'm concerned about is the webbing between the two chambers, below where they meet. It seems like there could be cracking if it gets too thin.
What do you guys think?
Mike n Mo
01-09-2008 04:46:38
 Re: How much to mill off of A2325R head? in reply to CenTexFarmall, 01-08-2008 21:22:09
I would advise you to get a late A head which has a smaller combustion chamber. Look for casting # A3367R or A4226R. These are found on late A's with a pressed steel frame. Late A heads have between 11-12 cubic Inch chambers verses 18 cu in for the A2325R head, and is 1/4" shorter. You might have problems with the pushrods being too long, and pay attention to the oil line adapter that goes on the center head stud. The oil hole is in a slightly different place, so make sure whatyou use doesn't block off valve train oil. Mike
CenTexFarmall
01-09-2008 19:31:12
 Re: How much to mill off of A2325R head? in reply to Mike n Mo, 01-09-2008 04:46:38
Thanks for the info.
4020LP
01-08-2008 23:06:59
You're probably not going to like this answer, but you asked, OK? Most of the A2325R heads will take a .125 cut, but it's cutting it mighty thin in spots. Also, please take into account that there's not an unlimited supply of cylinder heads, blocks, or connecting rods. Once the modifications that have been suggested so far have been done, there's no undoing them, and those are parts lost forever. If you want to do a gas conversion, do it the right way, and put some high compression pistons in your tractor. I'm aware that this solution costs more, but in the end, you'll have more success and less worries. I won't presume to tell you what to do or not to do with your tractor, just give this viewpoint some thought.
CenTexFarmall
01-09-2008 19:34:34
 Re: How much to mill off of A2325R head? in reply to 4020LP, 01-08-2008 23:06:59
I'm with you 100% on not screwing up irreplaceable parts! I have located pistons designed for a gas conversion. They're supposed to put C.R. about 6.5:1 and I can do a light cut on the head to clean it up. Thanks for the help.
bdpuller
01-08-2008 22:27:51
Might be better to leave the head alone and lengthen the rods for higer compression.
4020LP
01-09-2008 09:27:07
 Re: How much to mill off of A2325R head? in reply to bdpuller, 01-08-2008 22:27:51
Yeah, and what happens when one of those welded connecting rods break? Major damage. By the time you spend the money to have someone do that right (if indeed there is such a way), you'll have spent as much or more than high compression pistons cost, not to mention hacking up another pair of rods. Lengthening connecting rods to raise compression is just dumb when there are better solutions.
gtx1967jewison
01-09-2008 07:56:10
change piston pin placement (i.e. high compression pistons) not rod length.
