1934 FAIRBANKS RV2A MAGS
OLTWOPOP
01-07-2008 22:31:42
Any one know the meaning of the stamped numbers on these mags? The one's that are on the housing sides, flange bottom, mounting end, or inside of it. Are these date codes and serial #"s. If they are how do you read them? Did Fairbank stamp all the numbers? or did John Deere stamp part of their own build dates as they installed them?
Duane Larson
01-08-2008 11:44:57
 Re: 1934 FAIRBANKS RV2A MAGS in reply to OLTWOPOP, 01-07-2008 22:31:42
OLTWOPOP,
I looked at mine (off the tractors) and one has no markings, other than the DRV2A and the magneto s/n, while the other has 334 stamped on the flange, covered by the mounting gasket. It was not unusual for magneto repair shops to stamp magnetos when they were sent for repair, and that is probably what you are seeing. I have seen that a lot on magnetos sent for repair.
OLTWOPOP
01-08-2008 17:45:27
 Re: 1934 FAIRBANKS RV2A MAGS in reply to Duane Larson, 01-08-2008 11:44:57
Duane there is a three digit number under the flange gasket like you said, But I have a seven digit number on the outside bottom of the lower flange. I don't think this # was put there by a repair shop. Sorry, But I won't give them # out on open forum. The condensor is held in place by two little screws. Do they make a replacement part for them?
Duane Larson
01-08-2008 18:51:01
 Re: 1934 FAIRBANKS RV2A MAGS in reply to OLTWOPOP, 01-08-2008 17:45:27
OLTWOPOP,
Deere did put s/n on carburetors, according to Field Service Bulletin 82, but for FM magnetos their parts lists referred to the s/n installed by FM. I'm not sure what your number refers to, or who put it on, as I have not found any info from Deere indicating that info. I suppose it could refer to an update installed after the magneto was manufactured, like installation of an AlNiCo magnetic rotor or something.
The AA425R (FM-H2433) condenser is no longer available. The normal solution is to unsolder the case, remove the old condenser foil and insulator, install a modern condenser with capacitance between 0.19 and 0.21 mfd, working voltage over 500, and solder or epoxy it shut. The trick is to locate a condenser with an adequate working voltage and capacitance that will fit in the case.
