flywheel nut
54/60
01-07-2008 16:30:37
I am trying to locate the large nut that holds the flywheel on to the crankshaft I have tryed many web sites and have had no luck. If any one knows where I can find one new or used that would be great. My tractor is a 1954 john deere 60.
Mike M
01-07-2008 17:40:04
 Re: flywheel nut in reply to 54/60, 01-07-2008 16:30:37
Is it a hex tin nut original JD, or a large square 1" thick piece of steel if it is this than you have a taper-loc fylwheel and can get parts from Allen Machine in Tenn. 423-753-5738
Dean Sunram
01-07-2008 17:16:55
You can get a new one from your John Deere Dealer. The part number is A3312R & the price is $45.94 or go to a salvage yard & get a used one for alot cheaper. The later Model A's uses the same one. GOOD LUCK
LarrySTN
01-07-2008 17:03:51
Try John Deere, ask for part# A3312R, they aren't cheep but available $43.75
