?s for RobMD-cornhead grease
Curtis70
01-07-2008 14:36:17
I have the steering(manual) apart now on my 70 and have decided to use the cornhead grease. Will this make it more difficult to steer(will not be using the tractor at temperatures below 55 degrees)? Also, about how much will it take to fill it and what size containers does it come in? Thanks in advance for your help.
Mike Aylward
01-07-2008 16:34:56
 Re: ?s for RobMD-cornhead grease in reply to Curtis70, 01-07-2008 14:36:17
Curtis, I use cornhead grease in all my old tractors. You will not notice a difference in steering effort. Cornhead grease is a grade 0 grease which means it is softer than regular gun grease which often is a grade 1 or 2. It's main purpose is, obviously, to be used in corn head gearboxes. Contrary to what some people think, it softens when heat is applied (such as in a cornhead gearcase). Some manufacturers use gear lube in their gearcases but Deere has used this grease ever since the 40 series corn heads were introduced for the '70 model year. I usually keep several tubes around and use it in auger gearboxes, grain cart gearboxes, etc. It works very well in a steering gear and has extreme pressure additives as well. This, and it won't leak, either. It will flow around the gears just fine. Use it with confidence. Mike
RobMD
01-07-2008 15:13:44
That cornhead grease is available at your John Deere dealer on the shelves. They usually come in gun cartridges and very rarely, in one gallon pails. Buy the one gallon pail if you could, but really, you'll need about 3-4 tubes.
Try some, and see how you like it. It's green, it's sort of sticky, but it doesn't break down and dribble down my steering shaft.
