630 not getting gas
ccrock
01-07-2008 12:52:39
I"ve had a 58 630 for about 3 months now and today the carb stopped getting gas. After a little investigation I discoverd the little wheel on top of the sediment assembly. Wheel depressed gas flows, not depressed no gas. My wheel will not stay depressed, I took the assembly apart and it appears that a 1/4 turn will keep it depreesed but it looks as if the first bump you hit it will pop up and shut the flow off. I think I"m not understanding this fuel system (sediment bulb assembly), could someone please explain it to me.
fixerupper
01-07-2008 17:34:46
 Re: 630 not getting gas in reply to ccrock, 01-07-2008 12:52:39
I thought about this awhile before I posted because I don't want to sound like a know-it-all, but the main reason for the shutoff is to help prevent the crankcase from filling up with fuel if the float valve in the carb leaks while the tractor is shut off. I would think an engine running hard and hot might not survive the amount of time it takes to suck the carb dry if a sudden oil pressure loss occures. Jim
Tom43
01-07-2008 16:46:31
Your tractor has the oil pressure operated automatic fuel shut-off valve. the little knurled knob can be used to manually overide the oil pressure controlled valve. By unscrewing and depressing the knob you can fill the carburetor if you accidentally run out of fuel. this saves a lot of cranking waiting on a build up of oil pressure. The knob does not have to be out for the automatic valve to work. Diaphragms and plunger O ring are available from your dealer. As others said, be sure you have oil pressure!
buck eye al
01-07-2008 15:37:29
The other guys are exactly right. I only offer this because unless you understand the sediment bowl assembly's design and function you may not understand their replies very well. Since you're asking I'ma thinkin you don't. Not insulting anybody, stepping on toes or poking fun, just hoping to maybe help out a bit.
That bowl assembly is designed to shut the engine down whenever the engine looses oil pressure! If you loose oil pressure for any reason, fuel delivery to the carb is automatically stopped. When the carb runs dry (not long) hopefully the engine and your wallet both are saved from catastrophe!
Manual opening of the fuel bowl shutoff assembly (you've figured that out) is for those times when it quits because the fuel tank was too small. When you get back to the back fence line where it quit with a can of gas, you could operate the assembly manually to fill the carb. Then it would usually start right up without hesitation.
Like the others said, check the oil pressure and now you know why!
Hope that helps.
buck eye al
01-07-2008 15:38:42
 Re: 630 not getting gas in reply to buck eye al, 01-07-2008 15:37:29
Looks like Rob was jsut a bit ahead of me.
Later.
RobMD
01-07-2008 15:24:02
In a proper system, the tractor should receive gas from the sediment bowl as soon as the engine oil pressure reaches a significant level. The brass nut should remain LOOSENED all the way to the stop, and should basically "flop" around.
Now I have a question, does the tractor start when you depress the thing for about a minute or so? If the gas is indeed flowing but the tractor does NOT start, then the sediment assy. is NOT to blame. However, if the tractor does start, then you might have to check that engine oil pressure. If you're running a healthy 15 pounds at mid throttle, then the auto-shutoff will function well. If so, look elsewhere.
machinery-man
01-07-2008 13:27:43
Mike M. may be onto something....this is not a wheel but a round nut. If you tighten it up, It will close fuel from coming in even with oil pressure...backed off you can push it to let fuel in. If you took this apart it has to be reassembled properly, there is a small pin in the center of the diaphram and proper assembly is needed to operate correctly. There should be an in and out oil pressure line. While its your tractor and your dollar I would recommend that you investigate before taking many things apart, this post will help as these things are out of sight price wise. I think the new pressurized fuel shut off is now over $100 but with care you can only replace the diaphrams and the seating ring. If you replace the seating ring you will need to remove the small c type key...also I always flat surface the intake area with a file.
Mike M
01-07-2008 13:08:38
Engine oil pressure is to keep it depressed. The little wheel and bolt you push on only to fill fuel bowl manually or if you need to drain the system. I'd be checking my engine oil pressure.
Old Bob
01-07-2008 18:09:33
 Re: 630 not getting gas in reply to Mike M, 01-07-2008 13:08:38
I bought a 630 in November. I had to rebuild the fuel shut off valve. All the parts are available at JD. There are a couple of diaphragms in the valve assembly, possibly one or both of them have a hole in it. Also there is a rubber plug, possibly not the right word, that is in there also. Mine was stuck, so that was the reason I could get no fuel. I am no mechanic, but was able to do this, so it will be a piece of cake for you.
