620 o-ring replacement
jdjack
01-06-2008 19:04:04
In the govener housing just ahead of the hyd. pump there is a idler gear shaft the runs the pump. Well there is engine oil leaking from the left shaft end. According to the part book there is a o-ring there. How do I go about replacing the o-ring?
Does the govenering housing need to be removed?
430WLPG
01-06-2008 19:21:21
 Re: 620 o-ring replacement in reply to jdjack, 01-06-2008 19:04:04
No, just remove the hyd.pump and you can get to it , Just don't drop thrust washers as you remove the pin
jdjack
01-06-2008 19:27:50
 Re: 620 o-ring replacement in reply to 430WLPG, 01-06-2008 19:21:21
where does the pin come out? Side of the housing or inside?
Mike M
01-07-2008 05:16:58
 Re: 620 o-ring replacement in reply to jdjack, 01-06-2008 19:27:50
There is a small retaining pin under the hyd. pump you need to remove first then you can remove the larger pin to the outside left.
