70D Cylinder Head Removal
Blksmok
11-01-2003 19:23:56
Got everything on the topside removed, removed the ten head bolt nuts. Now, what's the best way to jar the head loose from the block with out breaking something?Thought I would ask before I start hammering on it. Thanks!
GPULLER
11-03-2003 08:15:49
 Re: 70D Cylinder Head Removal in reply to Blksmok, 11-01-2003 19:23:56
Blksmok,
If you do have a cracked head and need a replacement I have 70D and 720D heads for sale.
70D F1958 720D F3211R.
buickanddeere
11-02-2003 18:14:42
When it's already partly torn down you may want to consider the timing gears. Our 70D ate two sets before getting upgraded to the beefy 720 set.
Bob
11-02-2003 12:23:00
Put the nuts back on the head studs, a fraction of an inch from being in contact with the head, and crank the engine over. That should pop it loose.
Mark
11-01-2003 20:02:00
Best done with a 4" x 4" block of wood and 8 lb sledge hammer...takes 2 peolple, just pound on the edge or lip of the head that sticks out on the side of the head.
Clooney
11-01-2003 19:49:52
Blksmok, they will usually come loose like Frank suggested but if someone has used a good hardening sealer on that gasket it won't come off quite so easily & may require a small hydraulic jack or even jacking the front of head up from below to break the seal.....
~One word of caution: some people pull the head with the injectors still in the head. Personally I DON'T. Those injector tips are expensive & are easily damaged when removing that heavy head. You might want to pull the injectors first if you haven't already done so....
Blksmok
11-02-2003 10:43:33
 Re: Re: 70D Cylinder Head Removal in reply to Clooney , 11-01-2003 19:49:52
Clooney..I usually remove the injectors first and take them to our local JD dealer to have the cracking pressure, spray pattern and leakage checked. It wouldn't take much to damage those little tips that protrude through the bottom surface of the head. Later.
F-I-T
11-01-2003 19:27:49
Bruce:
I used a hard wood block and lopped against the manifold a few times. I just put the manifod back on and wapped it. It won't take much. The lead washers are probably just holding it fast. I also wapped it on the drain plug. Just use an old wood fence post, and you can thump it without shocking it.
Frank
Blksmok
11-01-2003 19:37:59
 Re: Re: 70D Cylinder Head Removal in reply to F-I-T, 11-01-2003 19:27:49
Frank.....thanks, I'll put the exhaust manifold back on and "nudge" it a few times with a wooden post. Anxious to see if I have a bad head gasket or a cracked head. It was leaking exhaust and oil into the coolant sytem. Later.
Blksmok
11-02-2003 10:13:34
 Re: Re: Re: 70D Cylinder Head Removal in reply to Blksmok, 11-01-2003 19:37:59
Frank..... ..I put the manifold back on and used a 4" x 4" and a sledge hammer, got it to pop loose with about two "persuasions". The head gasket was bad on the pulley side piston at the "8 o'clock position" (looking from the front) block stud. A portion of the gasket was completely gone allowing combustion gases a direct route into the coolant channels. Noticed some pitting on the top of the valves and the cylinder head portion that is open to the piston action. So, it's probably had this leak for sometime. Later.
F-I-T
11-02-2003 12:23:07
 Re: Re: Re: Re: 70D Cylinder Head Removal in reply to Blksmok, 11-02-2003 10:13:34
Bruce:
Good Deal!
Are you going to have that head checked for warp? I have been surprised at how a good looking diesel head can have some high/low spots, especially when they've blown a head gasket. I hope the block is true. One time I cleaned the and block really well and reinstalled the newly planed head on it without the gasket using some bits of Plasti-gage, and it was pretty revealing. Found a significant low spot on the block.
This little VAC had been run very hot at times, and the block deck is very true, but the head had quite a bit of twist in it. Glad I had it decked.
Frank
Blksmok
11-02-2003 21:00:15
 Re: Re: Re: Re: Re: 70D Cylinder Head Removal in reply to F-I-T, 11-02-2003 12:23:07
Frank... I was planning to just replace the head gasket, but maybe I should have the head checked for flatness. I run a straight edge across the area that leaked and it looks ok. I see the service manual says to use #3 Permatex(??) on the block side of the head gasket on reassembly. What's your opinion about that?? Later.
F-I-T
11-03-2003 04:33:20
 Re: Re: Re: Re: Re: Re: 70D Cylinder Head Removal in reply to Blksmok, 11-02-2003 21:00:15
If you checked it with a good straight edge and a feeler gauge you should be ok.
I used the copper coat stuff on mine, but both the block and head had been decked. I've never gone wrong following the manual, and the permetex products work pretty well for me. I use it as my sealant of choice.
I'd use it especially since you're going to have two "used" surfaces.
Frank
