JD 5520 PTO clutch Adj
Rod A
01-06-2008 12:58:30
What is the proper way to adjust the PTO clutch on this tractor?
Helped the owner replace the clutches.
He doesn"t have the service manual for the tractor.
Floyd A tn
01-07-2008 10:57:59
 Re: JD 5520 PTO clutch Adj in reply to Brandon Thompson, 01-06-2008 12:58:30
1. Move pto lever to reward position (disengaged)
2. Loosen jam nut at rear of yoke.
3. remove nut and disconnect yoke from pto clutch are.
4. Adjust length of cable so that yoke can be inserted with the cable pulled forward and the pto clutch arm pulled rearward to eliminate any free play. Lengthen cable by 1/2 turn of yke to provide slight lever play.
5. Connect yoke to pto clutch arm with cap screw and nut.
6. tighten jam nut to yoke.
This is what the book says. If you need any more information, I'll see what I an find..
I have a 5420 and this book is for the 5220 through 5520 tractors..
Rod A
01-07-2008 12:43:15
 Re: JD 5520 PTO clutch Adj in reply to Floyd A tn, 01-07-2008 10:57:59
Thank yoou for your reply!!!!! It is the info I needed.
Rod
Floyd A tn
01-06-2008 14:58:45
 Re: JD 5520 PTO clutch Adj in reply to jdhbag, 01-06-2008 12:58:30
Do you have a linkage or cable?
Rod A
01-07-2008 09:22:20
 Re: JD 5520 PTO clutch Adj in reply to Floyd A tn, 01-06-2008 14:58:45
It is a cable on this tractor.
Rod A
01-07-2008 09:20:12
