730 power steering issue???
n.carolina
01-06-2008 12:54:26
When tractor is cold and cranked the steering wheels turn immediately to the left; Still cold, as you re-center the wheels they will still turn to the left; AS the tractor gets warm the wheels will stay straight. There is no noises, whines, etc.
What could my problem be?????
Secondly, how hard is it to replace seals in the lower power steering unit??? Any advice appreciated.
machinery-man
01-07-2008 04:22:43
 Re: 730 power steering issue??? in reply to n.carolina, 01-06-2008 12:54:26
One thing, with wheels on the ground you need to check your tire pressure for evenness as this is will change drag one or the other way.
machinery-man
01-06-2008 16:09:37
MSD is correct, it doesn't take much of a movement to center the control valve. Suggest that you are careful in adjusting to stay clear of the wheel movement, I've adjusted with front wheels off ground if you have real good supports but you can go it on ground. I wouldn't worry much about seals if the steering works good after adjustment. You might consider changing fluid. These are great units but went bad a lot due to lack or no maintenance.
MSD
01-06-2008 13:50:21
It's not that difficult to change them out. I just finished my 620 yesterday. I rebuilt the pump also as long as I had the oil drained out and only wanted to make the mess once. Your steering valve may need adjusting to get it to stay centered. If thats it, it is no big deal to adjust. Just loosen the 4 bolts holding it on and give it a slight tap with a hammer. Tap it to the rear and it will turn to the flywheel side, tap it to the front and it will turn to the clutch side. It doesn't take much so go lightly.
RobMD
01-06-2008 22:00:01
 Re: 730 power steering issue??? in reply to MSD, 01-06-2008 13:50:21
Oh yeah, even a 1/4 inch accidental tap is enough to send the wheels flying into your knees and knocking you over... yup, that's me! :)
