Perhaps you've got some sort of reading-comprehension problem. First - in reply to your comment "to rely on a engine rebuilder is certainly not a waste of money! " . . . I never said is WAS. I said: ". . . nothing wrong with that if you don't mind spending (perhaps wasting) the extra money." Note my inclusion of the word "perhaps" - which meant to mean sometimes - not always. In regard to tolerances and what made John Deere famous. John Deere originally sold those tractors to be used, all day, everyday in many cases. Their intention was not to produce collector's tractors that led a life of "semi-retirement" which many of these old tractors do. I've got 40 years experience working on Deeres - and have had the occasion to see many last a long, long, time when put together in a worn, but useable condition. I was working on the two-cylinder Deeres when they were used daily on the farm and Deere Co. still gave parts support for them. I don't think you're going to tell me very much new about them that I don't already know. As to your comment/complaint: "Not that critical" isn't a descriptor this man can deal with. Service literature contains values. Are you telling this forum not to be concerned with those values?" More reading comp. problems on your part? I said - and I quote myself: "Go by the book since clearances are totally different depending on split-skirt cast-iron pistons or cam-ground aluminum." Note the word "book." And - about your comment about me giving a "kick in the pants" to engine rebuilders? No, I did not. I alluded to the idea that the guy many not need one (again, note the word "perhaps). I don't know what this person's skill level is. I will also add, that in many occasions, I've seen people pay a lot of money for work they could of done themselves. That's fine for some. But, considering the context of this forum, some people strive to be more than "parts changers." Many of these tractors, with reasonable wear, certainly can be put back together with a minimum of parts and run well for years. And yes - a low compression engine that runs at low speeds is more tolerant of cylinder wall imperfections than other, more modern engines. And - now I will give a slight "kick in the pants" to some engine shops (note, not all!). At the last two Deere dealerships I worked at - we had our own diesel injection pump shop (Stanadyne and CAV certified), we did our own cylinder head rebuilding, rod resizing, etc. Towards the tail end of my working there, the popular trend got to be more of sending stuff out to the machine shops. The cost to the customer got much higher, not lower and the quality of repairs was no better. I sold my own Sunnen honing machine about five years ago since parts - even stones were too expensive. Last year, I was rebuilding an IH diesel engine and sent all four rods to the local automotive machine shop to get checked for roundness and resizing if necessary. The guy charged me $80 and subsequently ruined all four rods. Ends up his hadn't calibrated his mike recently and he claimed someone must of dropped it. That led to a hunt to find four used rods somewhere for a 1959 tractor. When he finally did - he tried to charge me for them - which I did not. So - I'm sure that sort of thing does not happen often - but it taught to continue to do all I can, myself - when possible.
