Calling Machinery-Man or ET.
Rick Kaufmann
01-06-2008 09:20:44
Hi Guys:
I"m the fella who posted the questions about repair of an 810 plow a couple of days ago. I have located what appears to be an 810 that could be used as a parts plow and I think it can be bought reasonably. The present owner recently plowed with it and states that it has never tripped on him. My question this time is regarding the tail wheel. The owner says his plow has a tail wheel (no gauge wheel), but the wheel has a rubber tire. I thought the 810"s all came equipped with a steel tail wheel. Do you guys know of any of these plows ever having a rubber wheel?
Also if you get a chance take a look at my previous post again if you haven"t already. There"s a few other questions in my last response. Thanks again.
Rick
ET
01-06-2008 14:01:26
 Re: Calling Machinery-Man or ET. in reply to Rick Kaufmann, 01-06-2008 09:20:44
The 4.00x12 tire on the back was an option as someone else has said. The gauge wheel is only necessary when that plow is used on the old 800 hitch or a tractor with no draft control. I bought a manual for my 810 plow from JD a couple of years ago it cost $35 and is for a 810AM plow that is a little newer but the setup is basicly the same. Then I got an origonal 810 manuel off ebay for $15 so I would watch ebay for the book. The 1/2" of side to side movement has to be gotten out of your beam to ever work right. I used a latch roller and a known good beam for a pattern to build up the knotch on the beam. There is not much diffrents between it trips too much and it won't trip at all, but with a little playing around I got one to work pretty good. If you get the parts plow and you switch over the whole standard be sure to take apart, free up and lubricate the trip latch and beam. I like to use never sieze on that stuff.
machinery-man
01-06-2008 12:24:38
per the invoice, came with rubber tire...I suppose this may have been for transport usages, I'd prefer the metal wheel but you can change later if you locate the metal wheel. Sounds like the plow you're looking at maybe the one to restore.....good luck...
Mike M
01-06-2008 11:48:53
I was thinking the one I had was equipped with a hard rubber rear tire and a steel gauge wheel. I think there was alot of combos available.
LittleD
01-06-2008 10:14:48
Rick,
The 810 Series came with the steel disk rear wheel as standard equipment but had as an option the rubber-tired rear wheel 4:00 x 12 inch tire and tube.
I am posting a date of manufacture list for the plows you might find useful.
Enjoy your plow, Rich
third party image
Rick Kaufmann
01-06-2008 15:23:27
 Re: Calling Machinery-Man or ET. in reply to LittleD, 01-06-2008 10:14:48
Thanks guys, excellent responses. ET, how did you go about building up the latch roller notch on your plow? I would assume cast (nickel) rod or spray metal. I guess I would rather go this route for now to build up both the pivot hole and notch on my existing standard due to the obvious cost savings over all. The owner of the potential parts plow said that on his plow the mold boards are thin and have quater-size holes thru them, and has a broken point. So these are of little or no use to me. My mold boards and shins are like new. Points have some wear, but for as much as I would use it, they should still be good enough for a long time. Trash boards are a little thin on their outer bottom edge, but certainly not an immediate issue. I would only need to replace the rear landside on my plow as far as the wear parts are considered. I have a 530 series tractor with load control. Might even be able to get by without a tail wheel if I would install an extra long landside on the rear bottom. It would be about a 3 1/2 hour drive each way to just look at this plow, probably about $60-$70 in gas and a hole day of travel etc. I think it would take about about $250.00 to get this implement. A new cast standard from JD is $300.00. I found another plow, that looks like an 810A with the gauge wheel that is only about 2 hours away that's supposed to be field ready, but he's asking $525.00. What do you fella's think? Thanks again for your help.
Rick
ET
01-06-2008 15:58:26
 Re: Calling Machinery-Man or ET. in reply to Rick Kaufmann, 01-06-2008 15:23:27
No special rod needed its cast steel. I used E6011 rod.
Rick Kaufmann
01-06-2008 16:51:08
 Re: Calling Machinery-Man or ET. in reply to ET, 01-06-2008 15:58:26
Wow, that's really good news. I would have thought that piece was cast iron. I could do the build-up myself, but am concerned about machining technique back down to spec dimension. ET how did you accomplish this? Thanks.
Rick
ET
01-06-2008 18:18:50
 Re: Calling Machinery-Man or ET. in reply to Rick Kaufmann, 01-06-2008 16:51:08
None of mine were worn that bad. I would take it to a machinist along with the pivot pin and ask him to make a bushing to fit the pin.
machinery-man
01-07-2008 10:00:29
 Re: Calling Machinery-Man or ET. in reply to ET, 01-06-2008 18:18:50
You know, I was looking at a friend's 810 and it had a solid rubber tire, how they installed, I couldn't say, factory press. Then I say another one that had an inflatable tire...who knows on this stuff, guess they used whatever was on hand.
