430 hydraulics
ccrock
01-06-2008 08:05:21
I recently purchased a 58 430W. The lift arms on it barely raise, they take forever and with no weight and will not raise with weight on them. The prev owner said he did not understand what could be wrong because he used the tractor in the spring to plow and it worked fine. It is full of fluid, probably to full, it's filled all the way to the top of the fill plug. Are there any possibility's other than a bad pump that may be causing my problem.It just seems odd to me the last time he used it it worked fine.
buickanddeere
01-06-2008 19:38:40
 Re: 430 hydraulics in reply to ccrock, 01-06-2008 08:05:21
Dual rockshaft or single? Any air leaks on the intake side of the pump?
Rusty Wheel
01-06-2008 10:40:58
Howdy. If the pump isn"t noisy or getting excessively hot, I would check the relief valves. The speed is directly related to gpm flow, and indirectly related to pressure whereas the amount of weight it will lift is directly related to pressure and indirectly related to flow. In your case it is possible that the pressure is marginal. If you need 10 psi to lift the hitch and you"re only getting 12 psi out of the pump, then you only have 2 psi to work with. This is assuming you have no leaks Remember, you won"t have pressure until you have resistance to flow. Hope this helps..... .RW
