H John Deere L.H. cam bearing
Big G
01-05-2008 13:54:08
Does anyone have a suggestion on the best way to remove the left hand cam bearing on a 1939 H straight spline cam. Mine seems to be very tight I have not had any luck getting it to break free from the cam shaft. Any help would be appreciated.
Mike M
01-06-2008 12:28:01
 Re: H John Deere L.H. cam bearing in reply to Big G, 01-05-2008 13:54:08
I seem to recall hooking a gear puller on them before.
Ray Happe
01-06-2008 14:06:43
 Re: H John Deere L.H. cam bearing in reply to Mike M, 01-06-2008 12:28:01
Mike M. How were you able to hook the gear puller on the left hand bearing. I am having trouble getting the bearing out far enough to attach anything to.
Mike M
01-07-2008 05:54:45
 Re: H John Deere L.H. cam bearing in reply to Ray Happe, 01-06-2008 14:06:43
Every job does present it's own unique challanges and techneics NEED to be adjusted acordingly. It's been a few years but I do remember getting a puller on them to get the gears off not so much for the bearing,but maybe you can hook it up and pull a little on both pieces to get it started. Someone before you may of used loctite too and then you will need heat to release it. I seem to remember only one puller I have would even begin work on those due to reach out and accross. The shaft may have to be driven out of the bearing.To the right. Clutch is likely going to need to be removed and also make sure the LH nut holding the bearing on is too as it is under the tin cap.
