Removing JD Model A Cylinder Question
Bill M from Ill
01-05-2008 12:19:03
I think it's a 1951 model. Can the cylinder be removed from block without removing frame rails? Looks to be a tight squeeze and it may be easier to just unbolt and pull frame with front wheels forward. Any suggestions? Thanks in advance. Bill
jdhbag
01-05-2008 17:20:23
 Re: Removing JD Model A Cylinder Question in reply to Bill M from Illinois, 01-05-2008 12:19:03
It comes out the bottom. I speak from experience, just happened to take mine out of my 52 A about an hour ago. Two of us did it without any trouble. The pistons were out of it and 2 of us had no trouble at all it just has to be rotated correctly. Good luck
Mike M
01-05-2008 16:45:28
That block will come out with the frame and fanshaft left intact. Any 2 cyl. I ever had will. It comes out the bottom if I remember right on your model.
01-05-2008 17:10:20
 Re: Removing JD Model A Cylinder Question in reply to Mike M, 01-05-2008 16:45:28
I wonder how much weight we're talking about here. It looks heavy; should it be blocked up or can two people handle it ok? Thanks again for help. Bill
Mike M
01-06-2008 06:37:43
 Re: Removing JD Model A Cylinder Question in reply to Bill M from Illinois, 01-05-2008 17:10:20
I have done it my self,but not recommended as I think mine got away from me. 2 people should be fine.
jd b puller
01-05-2008 14:26:06
 Re: Removing JD Model A Cylinder Question in reply to squezon, 01-05-2008 12:19:03
You don't have to unbolt the frame. slide the block forward, then rotate it 90*. The book says to remove it out the bottom, I've always taken it out the top.
If you decide to remove the frame rails, be really careful, the center of gravity is really high and it's very unstable. If the front pedestal is off, and the radiator, it's not too bad, I just use an engine hoist and pull it that way. I about killed myself once pulling the frame off with all that junk stil on there.
01-05-2008 14:12:49
We did manage to get everything out of the way but it looks like if we unbolt it from block and slide it forward to clear pistons it probably won't have enough clearance to lift up and out from between frame members. Looks like we'll have to unbolt frame and slide it forward to make it simpler. Thanks. Bill
jd b puller
01-05-2008 12:39:44
 Re: Removing JD Model A Cylinder Question in reply to Rob J., 01-05-2008 12:19:03
Yep, need to remove everything in front of it (head, manifold, water manifold, etc...). If you're taking it all down, it's a lot easier if the fanshaft isn't in the way - but that's a whole other project (gov housing needs to be moved back so you can get fanshaft out w/o buggering up the radiator.
